Author Topic: Cold running problem 1985 KRT1000  (Read 4342 times)
Offline pinhead
« on: March 14, 2024, 09:27:25 PM »
I have this problem that has plagued this bike for the past year.  It will cold start fine and then run a short while than conk out and won't start.  I have to turn the key off and let it set for a minute or two.  Then it will fire up.  After I get it warmed up, no problems it will restart easy.  What are the sensors, units on this bike that could affect this and where on the bike are they located?  thanks
  • sacramento, ca
  • 1985 RT 100
Offline blackie1
  • christchurch nz
Re: Cold running problem 1985 KRT1000
« Reply #1 on: March 15, 2024, 04:07:27 AM »
H.E.S.
  • 1991 K75RT naked 67,000kms
« Reply #2 on: March 15, 2024, 08:48:24 AM »
HES usually fails after it gets hot. This situation seems a little more interesting.
« Reply #3 on: March 15, 2024, 03:41:27 PM »
Maybe it's a bad coil or two, even more so if your brick is the earlier model. Or a spark plug, or lead.
« Reply #4 on: March 15, 2024, 04:13:55 PM »
Temperature sensor or it's wiring.  What is resistance between pins 10 and 13?
Offline pinhead
« Reply #5 on: March 16, 2024, 04:35:41 PM »
  thanks.  where is that temperature sensor located so I can check it?
  • sacramento, ca
  • 1985 RT 100
« Reply #6 on: March 16, 2024, 10:49:58 PM »
The pins used in the resistance test of the temperature sensor are located on the LE Jetronic fuel injection control unit plug attached to the control unit under the seat.
Offline pinhead
« Reply #7 on: March 19, 2024, 02:39:51 PM »
OK.  I have decided to replace the temperature sensor.  I called BMW dealership and they no longer stock the part.  Anyone have a suggestion where I can get a genuine bosch sensor?
  • sacramento, ca
  • 1985 RT 100
