Author Topic: What Else Should I Do During a Crank and Head Gasket Replacement?  (Read 3035 times)
Offline RetroTexan
First time I've ever needed to replace the crankshaft cover and cylinder head (inner/outer) gaskets. They are cracked and leaking oil. I was planning to check and adjust the valve clearances while I was at it. But what other maintenance should I do while I've got it cracked open?
  • San Marcos, TX
  • 1990 K100 Custom Scrambler
Re: What Else Should I Do During a Crank and Head Gasket Replacement?
« Reply #1 on: February 04, 2024, 01:21:49 PM »
The most important thing to worry about is only torqueing the cover bolts to spec. (8 Nm)  They are shoulder bolts and if you over-tighten them you will strip the threads where they mount.
Start with the center bolts and work outward in an X pattern.
You should also replace the rubber bushings on all of those bolts - part 11141460934
Agree Agree x 2 View List
Offline blackie1
  • christchurch nz
« Reply #2 on: February 05, 2024, 02:16:47 AM »
have you downloaded a repair manual?
lots of good tips in there.
for instance
"Cylinder head cover-installing
Apply a thin coat of Hi-Temp Black RTV Silicone Gasket Maker  to the front edge of the housing (cylinder head/timing case cover/cylinder
head cover).
also a smear on the half moons.
  • 1991 K75RT naked 67,000kms
« Reply #3 on: February 05, 2024, 12:13:48 PM »
What frankenduck said about replacing the rubber bushings.  Since the bolts are shouldered it's the bushings that actually apply pressure to the casting.  If they get old they might not apply enough to keep the new gasket from leaking.  And assuming you'll check valve clearances while you're in there.
