Author Topic: pistons and rings  (Read 3118 times)
Offline Shinyballs
pistons and rings
« on: January 09, 2024, 06:48:37 PM »
We are having problems trying to locate pistons and rings for an '86 K75C. To make it more difficult, the cylinders may have to be bored (waiting for machine shop to get back with a verdict of oval or round). If they need boring, we need oversized pistons and rings.
Is all this available somewhere? Anyone know? If not available, is there a compatible piston from a totally different vehicle?
Thanks
Ray
  • Ontario
  • 1986 K75C
Re: pistons and rings
« Reply #1 on: January 09, 2024, 10:15:16 PM »
See my reply on the other thread.  As far as I know there are no oversize pistons available.
Offline Duckbubbles
« Reply #2 on: January 10, 2024, 09:32:12 AM »
The cylinders are Nikasil (?) coated aluminum and are not to be bored any at all.  I have heard (in the way back past) of people boring and sleeving the block with steel liners.  Sounds awfully expensive.  If your block is really out of round, worn out, you would be better served to get a used block or whole engine from a wrecking yard.
The stock lining is extremely tough and unless there was some damage will last many 100,000's of miles.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
« Reply #3 on: January 10, 2024, 10:20:57 AM »
If the engine has gone bad then it is probably easier and cheaper to just get another engine with relatively low miles.
I'd recommend getting an engine built after June 88 with the newer, less smoky, pistons and rings.
Offline Shinyballs
« Reply #4 on: January 16, 2024, 11:02:42 AM »
The word from the machine shop is that the cylinders are fine, straight and round  112350. So they just did a ball hone to the cylinders, head resurface, valve seating and new valve seals. So we will have to find out which crank bearings and connecting rod bearings we need. As for the piston rings, I talked to a tech at BMW Motorad and after spending some time on the computer and on the phone, he could not locate rings anywhere. The rings are not available anymore. So we will put the engine block back together with the starter and check the compression. If it's better than it was before, we will just use the old rings. Unless we find an aftermarket, universal set of rings that can be trimmed to fit.
  • Ontario
  • 1986 K75C
Offline Duckbubbles
« Reply #5 on: January 16, 2024, 02:30:16 PM »
I am just throwing this out there in case someone else can confirm.
The K75 and K100 share the same bore size.  The pistons are different but I wonder if the ring lands are the same.  Supposedly, Realoem.com lists ring sets for the K100 P/N 11251460994 as still available.  Less than $70 each which is a shock and probably out of date price.  You can check your old rings for wear by inserting them into the cylinder and measuring ring end gap just like fitting new rings.  If the gap exceeds limits (.0098-.0177 in./ .250-.450mm) they are worn out.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
500,000+ BMW miles
« Reply #6 on: January 16, 2024, 03:11:46 PM »
Frank
$74.88
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=11251460994%20
Offline Shinyballs
« Reply #7 on: January 16, 2024, 03:59:43 PM »
Thanks for that, that is good advice and I'm going to check this out. Since the cylinders had a ball hone done I would prefer new rings.
as for the crank and connecting rod bearings, anyone know how to decifer the tri-color code for their bearings? They have yellow, green and white in either STUFE 0 or STUFE 1.
  • Ontario
  • 1986 K75C
