Author Topic: 85 K100RT Fuel Cap Assy Stuck  (Read 8395 times)
Offline volador
  • NEEDS MORE CHROME
Re: 85 K100RT Fuel Cap Assy Stuck
« Reply #25 on: November 10, 2023, 12:43:00 AM »
You scored a deal.
Actually there is more...
1- The original Water Pump had a different impeller type.
2- The original Throttle Cable explained under topic 7.0  https://ibmwr.org/index.php/k100-faq/
3- the Drive Shaft output side splines are Z-16 (16 splines later changed to Z-20 splines) and thus Final Drive input shaft is 16 splines
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline phildo253
« Reply #26 on: November 10, 2023, 12:46:19 AM »
Thanks for the info.   I will double check those as I tear the bike down.
  • PNW
  • 1985 K100RT
Offline volador
  • NEEDS MORE CHROME
« Reply #27 on: November 10, 2023, 01:03:09 AM »
Apply 303 Aerospace Protectant, Meguiars M40, or ArmorAll to revive all the plastic, vinyl parts
Check condition of the inside of fuel tank. Lowest portions & weld seams are prone to corrosion when moto is left sitting for some time.
Rubber fuel pump damper will disintegrate over time left sitting in petrol.
Some links for your K journey Good Luck
Just bought a 2V
Just bought a 4V
K75s midlife refresh
Check parts compatibility with BMW MAX Microfiche, BOBS BMW, REAL OEM
https://shop.maxbmw.com/fiche/PartsFiche.aspx
https://shop.maxbmw.com/fiche/PartsSearch.aspx
https://parts.maxbmw.com/BMW___BmwMotorradK.html
https://www.bobsbmw.com/store/microfiche/BrowseSeries.aspx
https://www.realoem.com/bmw/select.do?kind=M&arch=1
https://www.ascycles.com/BMW-Motorcycle-Parts-Fiche
Cross reference parts like Bosch pn#'s, etc....  http://partsplusecat.com/
No spaces in the part number
Parts Vendors
https://www.beemerboneyard.com/
https://www.capitalcycle.com/
https://www.euromotoelectrics.com/
https://www.tills.de/
Headlight relay stuff if you chose to add one
https://www.motobrick.com/index.php?topic=268.0
http://www.motobrick.com/index.php/topic,4962.msg30932.html
http://easternbeaver.com/Main/Wiring_Kits/H4_Kits/h4_kits.html  Eastern Beaver site is a great reference for electrical connectors,plugs, etc...
http://www.k100-forum.com/
http://www.kforum-tech.com/Tech-page.html
https://www.kforum-tech.com/forum-area/__Files/electrical/EFI/bike-wont-start-EN.htm
http://www.kforum-tech.com/Downloads/electrical/diagrams/interactive_diagrams.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/0.ckb.tech.files/k100tshoot/K100.Troubleshoot.Start.2018.pdf
http://kbikeparts.com/index.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.new2k.htm
http://www.kbikeparts.com/classickbikes.com/ckb.tech/ckb.tech.toc.htm
https://bmwk100k75.weebly.com/
http://www.eilenberger.net/K75S/IgnitionSwitch/
http://www.verrill.com/moto/moto.shtml
this site has a lot of good info and breakdown pictures in the tech and tech resources sections for K1100 alot of the parts are on K75 & K100
http://www.k11og.org/forum/index.php?sid=2df953dde5715fd9001fbe69edec5ad0
https://ibmwr.org/index.php/k-bike-tech-articles/
This site has all kinds of technical specifications on all the BMW models    http://www.bmbikes.co.uk/mechanicalpages/kseriesmechanical.htm
http://largiader.com
http://bmwk10075abs1fix.web.fc2.com/index.html  Toshi ABS site
Hosa D5S-6 CAIG DeoxIT 5% Spray Contact Cleaner, 5 oz.
CAIG Laboratories D100L-25C Contact Cleaner Needle Dispenser
Oil/Water Pump
pre-1986-87? original design old style impeller 11411461177
Superseded by 11412325850 design change the shaft with gear Z=32 teeth, shaft- 11411461183
Superseded by 11417676366 same shaft with gear Z=32 teeth
latest design 11517676371 design change shaft with gear Z=19 teeth, shaft- 11411461793
3-Bond 1184 Service Bulletin
Slip-ring seal for water pump Service Bulletin
Oil Water Pump Seals K-models SB 11 039 89 2352
https://www.euromotoelectrics.com/product-p/pumpkit870.htm
https://www.euromotoelectrics.com/product-p/pumpkittool628.htm
  • NYC NY
« Reply #28 on: November 10, 2023, 07:48:22 AM »
Because you have expressed an eagerness to geek-out on this Brick, the attached photo indicates two adjacent ports on the underside of the fuel tank. Their existence implies to me that your Brick is CA-compliant. One of those ports had a hose that was either attached to a port on the top of the forward end of the engine block, or was laid out to exit behind the right foot peg. Which was it?
Offline phildo253
« Reply #29 on: November 10, 2023, 08:59:39 AM »
Both hoses, neither of which were actually attached, went out the right hand side behind the foot peg.  The front top of my block doesn't have the port sticking out.
  • PNW
  • 1985 K100RT
« Reply #30 on: November 10, 2023, 09:32:35 AM »
Take another look; it's behind the radiator. In the diagram below the red box outlines the intake port in the block, the green lines indicate the hose path up to the tank. When it all goes back together, the block port should be capped, and the hoses that exit behind the foot peg plate should be connected to the tank. You can purchase a little frame-mounted cup to collect emissions direct from both tank ports; only one hose attaches to it, but you don't need it. It just makes tank removal slightly easier because you don't need to disconnect and connect those two emission hoses when moving the tank.
Offline phildo253
« Reply #31 on: November 10, 2023, 09:46:38 AM »
Ok.  I see what you are referring to in the drawing.  Attached are photos of that spot on my block.
  • PNW
  • 1985 K100RT
« Reply #32 on: November 10, 2023, 09:59:37 AM »
This must be one of those days when nobody can convince me of anything.  :laughing4-giggles:
Offline phildo253
« Reply #33 on: November 10, 2023, 10:02:36 AM »
Ha!  I love it.  I will try to get some better photos tonight.  Looking in that spot did show me a few more items that have to be fixed, so thats good.
  • PNW
  • 1985 K100RT
« Reply #34 on: November 10, 2023, 12:10:26 PM »
After my fourth cup of coffee, the red-circled area in one of your photos now appears to be likely evidence of where that port could have been mounted. Carefully remove the debris from that cavity using a shopvac, wet towels and a toothbrush to determine if the port was ever mounted there, and if there is a hole beneath that debris that should be plugged so dirt doesn't continue to enter the crankcase.
Offline phildo253
« Reply #35 on: November 10, 2023, 02:23:41 PM »
Definitely.   I will double check it tonight.  I think that it is part of the casting, but better to make absolutely certain.
  • PNW
  • 1985 K100RT
