Author Topic: K1100LT Carcass Research  (Read 3025 times)
Offline dbamberger
« on: October 15, 2023, 06:03:45 PM »
Hey folks.
I recently brought home some parts which I was told was a k1100.  I've done a VIN decode on it and the frame, at least, comes back as a 1996 K1100.  This was someone's project bike so most things are gone.  It does have the engine/trans/swingarm/final drive.  I'm wondering if there are ways I can identify what they are.  There's a casting on the engine block on the right side.  The number cast there is 1461479. Would that tie an engine to a VIN? Would it identify the engine at least?  Are there similar castings for trans and/or swingarm that are still covered in grime?
Thanks in advance.
dbam
  • Portland, OR
  • 1994 K75RT
Re: K1100LT Carcass Research
« Reply #1 on: October 15, 2023, 10:11:47 PM »
What are you wanting to know about them.
Offline dbamberger
« Reply #2 on: October 16, 2023, 12:10:50 AM »
Really basic stuff like:
* Is this motor really from a K1100?
* Is it the motor that originally came with the bike?
After that I haven't really thought about.
  • Portland, OR
  • 1994 K75RT
« Reply #3 on: October 16, 2023, 11:55:53 AM »
It's kind of late in the game to be identifying what you got; it must have been a bargain. Be happy you don't live in the EU or UK or elsewhere that having the original engine might matter.  :laughing4-giggles: Does it matter where you live?  177381 If it has a cam cover and underside mounts on the transmission as indicated in the images below, it's likely to be a K1100. The engine number is stamped on the sump as shown below; the VIN plate on the frame will identify the original unit.
Offline dbamberger
« Reply #4 on: October 16, 2023, 04:18:29 PM »
Thanks!
It was definitely a bargain(came with an Ohlins shock which I'm excited about) but a bit of "trust but verify" never hurt.  I'll go have a looksee in the areas you suggest.
Regards.
dbam
  • Portland, OR
  • 1994 K75RT
Offline dbamberger
« Reply #5 on: October 16, 2023, 09:17:57 PM »
Found this:
* 20231016_181137.jpg (71.24 kB . 768x576 - viewed 481 times)
  • Portland, OR
  • 1994 K75RT
« Reply #6 on: October 16, 2023, 10:47:16 PM »
This is your engine number: 114EA  11 96 2012  The following extract is the explanation about it from BMBikes.
A K Series engine number will look something like this: 104EA 1799 2032- the first two digits refer to the engine capacity (1000cc); the third digit shows the number of cylinders; EA is some reference to a Federal Emission Code; sixth & seventh digits are the production week number (week 17); eighth & ninth digits are the year of manufacture (1999); the final four digits are the production number on that weeks production.
Offline dbamberger
« Reply #7 on: October 16, 2023, 11:20:20 PM »
Fantastic.  Thank you!
  • Portland, OR
  • 1994 K75RT
