Author Topic: Alternator voltage regulator  (Read 3564 times)
Offline Lbxpdx
« on: September 11, 2023, 09:47:46 PM »
I have a spare regulator from my Volvo parts and it looks exactly the same, except it has a capacitor soldered across two points.  My stock regulator is at .2, while the Volvo one is .395.   Is it safe to assume that I can unsolder the cap and use the Volvo one?
  • Portland
  • 1994 K75S, 1992 K75RT, 1972 R60/5 & 1977 R100S
Re: Alternator voltage regulator
« Reply #1 on: September 12, 2023, 12:54:03 AM »
Still assuming, huh?  :laughing4-giggles:
I wouldn't say they look exactly the same, but be bold and let us know how it works out.
« Reply #2 on: September 12, 2023, 01:40:55 AM »
One unimpeachable source indicated Volvo regulator  244332 is a sub.
« Reply #3 on: September 12, 2023, 10:14:32 AM »
I'm going to go out on a limb and suggest that the capacitor on the Volvo regulator is for noise suppression and won't affect alternator performance running the electrical system.
« Reply #4 on: September 12, 2023, 12:10:16 PM »
I'm going to go out on a limb . . .
If the limb breaks, your Brick will still be charging the battery.  :laughing1:   Seriously though, give it a try, Lbx. A good outcome could help others. Any legible numbers on it?
Offline Lbxpdx
« Reply #5 on: September 12, 2023, 03:54:20 PM »
No numbers that I see.  I’m pretty sure I pulled this from a Volvo 240 out of a junkyard, and I’m pretty sure the 740/940 has the same alternator.
  • Portland
« Reply #6 on: September 12, 2023, 04:59:06 PM »
 112350
« Reply #7 on: September 14, 2023, 09:16:47 PM »
I’d be wary of the capacitor because of its age. It could be defective. I’d see if you can remove it unless you can test it.
Offline Lbxpdx
« Reply #8 on: September 15, 2023, 04:10:55 PM »
Once I get my monkey nuts in the mail, I’ll let you know how it goes.
  • Portland
Offline Lbxpdx
« Reply #9 on: September 23, 2023, 03:34:18 AM »
I unsoldered the cap and put the regulator in.  Works great.
  • Portland
« Reply #10 on: September 23, 2023, 01:53:04 PM »
For those of us not hip to electronic patois, cap refers to the capacitor indicated in Reply #7.
