Author Topic: K75RT connector problem  (Read 3201 times)
Offline Cdzn
« on: April 28, 2022, 08:33:17 AM »
Hello pals. I have K75RT and have some trouble with 12 volts coil wires. I can`t find any oem part number this plugs to replacing it. Could anyone help me to figure it out what exactly part number is it. They are just crashed and should be replacing to new one. Thanks a lot.
  • NL
  • K75RT 1996
Re: K75RT connector problem
« Reply #1 on: April 28, 2022, 09:03:37 AM »
I can`t find any oem part number this plugs to replacing it. Could anyone help me to figure it out what exactly part nimber is it
Use realoem to look up part numbers.
Put the year of your moto in your profile, too. There can be differences in parts according to the model year.
Offline Cdzn
« Reply #2 on: April 28, 2022, 11:03:25 AM »
Sorry, forgot about that. My 75RT 1996 year. Here is photo
  • NL
  • K75RT 1996
Offline Cdzn
« Reply #3 on: September 10, 2023, 07:48:50 AM »
Hi there. Still need this connectors. I made photo and try search this number, but have no luck.
* IMG_3606.jpeg (30.22 kB . 324x576 - viewed 492 times)
  • NL
  • K75RT 1996
« Reply #4 on: September 10, 2023, 07:13:22 PM »
Type the number into a post so it can easily be read by us. It's likely you'll need to make accurate measurements of the diameter and depth of the sockets that receive the coil pins.  Post those measurements here, also. There is likely a two-pin female connector in the aftermarket—used part or new—that can work.
Offline Cdzn
« Reply #5 on: September 11, 2023, 06:51:52 AM »
The number is 1459515. Forget to measure depth. But i guess it’s around 8-10 mm.
  • NL
  • K75RT 1996
