Author Topic: 3 spoke wheel  (Read 4433 times)
Offline ming
3 spoke wheel
« on: September 09, 2023, 07:36:34 AM »
hi all
i saw this bike advertised on fleabay, its an k1100 with the non floating discs, 4 stud fixing same as the k100, what wheel is this off as every other k1ioo wheel i've looked at is mounted differently?
many thanks
ming
  • derby
  • triumph street triple, spondon bandit, honda cb 500 fa, bmw k100, honda tlr 200, yamaha ty 250 mono
anything is possible!
Re: 3 spoke wheel
« Reply #1 on: September 09, 2023, 12:34:08 PM »
That looks like a K100, ming. It has a 2-valve K100 camshaft cover, 2-valve air intake system, and two-pot instead of 4-pot brake calipers.
Re: 3 spoke wheel
« Reply #2 on: September 09, 2023, 01:10:36 PM »
Incidentally, the front discs on that Brick are floating discs which, as is obvious, can be had for K100 and K75 models. The fork looks K100. The wheels are likely stock 2-V mounted with the widest tires that will fit between the fork legs without rubbing them.
Offline ming
Re: 3 spoke wheel
« Reply #3 on: September 09, 2023, 02:18:43 PM »
hi laitch
so that front wheel is from a k100? thought only the later k1100 and the rt models had 3 spoke? as i said earlier the discs are definately k100 but i can't reference a three spoke with those discs?
cheers
 ming
  • derby
Re: 3 spoke wheel
« Reply #4 on: September 09, 2023, 03:14:10 PM »
I've discovered in my life that thinking isn't everything it's cracked up to be, ming.  :laughing4-giggles: Attached is an image from MaxBMW's parts fiche showing a three-spoker front wheel available for the 2-valve K100 models in the later years of their production. The late K75 models could get them, too. Mine has them.
Offline ming
Re: 3 spoke wheel
« Reply #5 on: September 09, 2023, 03:16:46 PM »
cool, thats some good info there m8 !! will do a search for those
cheers
ming
  • derby
Re: 3 spoke wheel
« Reply #6 on: September 09, 2023, 06:15:04 PM »
The rotors are EBC:
left   MD 604 LS
right   MD 604 RS
