Author Topic: Light popping/burble on acceleration  (Read 36160 times)
Re: Light popping/burble on acceleration
« Reply #25 on: August 31, 2023, 06:08:06 PM »
Darkness warshed over him when he went to the dark side.
That could actually have been a drenching in sheep dip.
« Reply #26 on: August 31, 2023, 06:26:07 PM »
Actually I should have said darkness warshed over the dude, without even going to the dark side.
« Reply #27 on: August 31, 2023, 06:30:10 PM »
You're such a stickler for details.  112350   Your prose fully conveyed the salient point—it's dark in there, wherever it is.  :tinhat2:
« Reply #28 on: September 01, 2023, 08:15:08 AM »
I felt like posting the YouTube clip, but I found the will power to resist the urge.
Offline Lbxpdx
« Reply #29 on: September 04, 2023, 07:55:43 AM »
I installed NGK plugs and wires last night and I’m hoping to take the bike for a spin later today.  My plugs looked great, a nice tan color, but I figured since I couldn’t test the stock plugs, I should probably buy some that could be tested.  I did notice a difference when goosing the engine in neutral, with it responding much smoother and faster than before.  I will report back later today.
  • Portland
  • 1994 K75S, 1992 K75RT, 1972 R60/5 & 1977 R100S
« Reply #30 on: September 04, 2023, 12:00:09 PM »
Did you measure the electrode gap before you installed them? Did you measure the gaps of the plugs you removed?
Offline Lbxpdx
« Reply #31 on: September 04, 2023, 12:01:07 PM »
I did measure the new plugs and if I recall the old plugs were in spec too.  The old plugs were Bosch.
  • Portland
Offline Lbxpdx
« Reply #32 on: September 04, 2023, 01:54:46 PM »
Do I need the terminal plugs if I’m using NGK plugs and wires?
  • Portland
« Reply #33 on: September 04, 2023, 02:45:02 PM »
It's likely you will need terminal nuts. You can determine that by looking into the opening in the wire that receives the spark plug terminal. Is it the width of a bare terminal screw or the width of a terminal nut?
Offline Lbxpdx
« Reply #34 on: September 04, 2023, 02:47:01 PM »
Thanks.  It obviously needs the terminal nut.  I also found out that the NGK wires seem to lock on the terminal nut, but in actuality they need a real good push to get that “pop” when the cap seats on the plug.
  • Portland
« Reply #35 on: September 04, 2023, 02:48:24 PM »
That is a typical good fit.
Offline Lbxpdx
« Reply #36 on: September 04, 2023, 11:41:13 PM »
Well, the plugs and plug wires didn’t change anything.  Still has the hesitation and popping on acceleration.
Two things I did find out while fiddling around today.
When the bike is left on its side stand while idling, it will eventually die.  I never use the side stand, so this is new to me.
Second, when I pressed the starter button while the bike was running around 1k rpm, it attempted to engage the starter button.  I just recently cleaned the switch, and from my reading it the starter switch runs through the ICU.  The ICU, if I am correct, should. It allow the starter to engage if the rpm is above 770.
I’ve cleaned the ICU plug with DeOxit and the grounds under the tank.  Is it possible that I may need a new ICU?
  • Portland
« Reply #37 on: September 05, 2023, 12:53:29 AM »
On a K75 the revs need to be over 1000 RPM otherwise the starter will engage.
« Reply #38 on: September 05, 2023, 01:06:47 AM »
It dies if left on the side stand.
I feel that if there is water in the tank, it might double the amount of water under the pump while on the side stand cause they're both on the left.
This could be another good reason to double check if the replaced fuel filter is partially blocked.
Water in the tank might be difficult to see, especially with fuel circulated and mixed by the pump.
Offline Lbxpdx
« Reply #39 on: September 05, 2023, 01:22:52 AM »
There is no water in the tank.  I emptied completely, took everything out and cleaned it.  I just filled up today with Chevron 92 and I did take a peak inside with the cap off while it was running to see if I could spot any bubbles or gushing fuel.
The filter is a BMW one that was quite easy to blow through.
I feel like it runs great under 3k and that is when the popping starts and the hesitation.  Maybe I need to go over the TB rubbers again and spray some carb cleaner or the like.
Many moons ago, there was this great group of airheads that would get together here in PDX.  I don’t know if any brickhead gatherings in the area.
I guess I’ll keep chugging along until I figure it out.
  • Portland
Offline Lbxpdx
« Reply #40 on: September 05, 2023, 01:23:28 AM »
Good to know.  Thanks.
  • Portland
« Reply #41 on: September 05, 2023, 02:25:34 AM »
One of the other suggestions was to check the fuel pressure, it might be low.
One of the things I'm thinking is does it only happen when the engine is warm? Or does the fuel pressure drop when it happens, like say a hose has a temporary kink, since it seems to be temporary, but dunno how long it lasts before it comes good, or when it comes good.
Offline Lbxpdx
« Reply #42 on: September 05, 2023, 10:14:12 AM »
I’m hoping to get a fuel pressure gauge in the next few days.
I think I will go back and check the fuel lines, as I just replaced them with regular fuel pressure rated hose.
  • Portland
« Reply #43 on: September 05, 2023, 06:37:05 PM »
The original hose has a formed 90 degree bend near the tank, check it out. If that's the problem you might be able to fix it with a spring type thing, If that fixes it, you probably don't need to check the fuel pressure.
« Reply #44 on: September 05, 2023, 09:15:48 PM »
You should be able to borrow fuel pressure gauges at no charge from Advanced, AutoZone or NAPA. If the fuel pressure at the rail is okay, the next step is clear.
Back in Reply #1, Mighty Gryphon asked if you had checked the valve clearances. You didn't respond. It's time to get the materials together to do that; it's an essential task with a newly acquired used Brick because inaccurate clearances and poor throttle balance affect both performance and engine lifespan. Gryphon made a post describing an effective homemade balancing rig. Once it is established that clearance are in spec, you'll need to balance the throttle bodies. Put this off no longer. clearance check Instructions abound. Among them is this one.
Offline Lbxpdx
« Reply #45 on: September 06, 2023, 11:49:47 PM »
Fuel pressure regulator tested perfectly.
Throttlebodies have been synced.
I can’t find my feeler gauges, so I decided to order some for k bikes along with some consumables.  Valves were checked at dealer and were within spec 10k miles ago.
I still feel that the idle drop when on the side stand may have something to do with the main issue.
  • Portland
« Reply #46 on: September 07, 2023, 07:39:58 AM »
Did you use special hose inside the tank suitable for being submersible in fuel, and has this problem occurred some time after you replaced the hose? If not small bits of rubber might be floating around inside the rail and/or the injectors, or along the supply and/or return line.
Offline Lbxpdx
« Reply #47 on: September 07, 2023, 09:22:24 AM »
I only replaced the exterior fuel lines.  I inspected the lines in the tank and they were fine.  There has always been this light surging since I bought the bike.  I’m just trying to track it down as everything else on the bike seems great.
  • Portland
« Reply #48 on: September 07, 2023, 11:48:55 AM »
If, as you seem to be indicating, you can induce surging by leaning the Brick onto its side stand, that is BIG news. Replication is a key element of proving an hypothesis. All you need to do is consider which elements could be affected by gravity, or G-forces (as in the case of occurrence at speed). Pick one after another—wiring, hoses, switches, for example—and wiggle or move them attempting to cause an effect while the engine is running in neutral on its center stand.
The pedestrian element of a defective fuel pressure regulator should be resolved. Verification of work claimed to have been done, such as valve clearance measurement, should be undertaken. Many owners seem to have been disappointed by BMW service centers.
Obstruction in the air snorkel should be investigated. Another element to consider is the air flow meter. Is there obstruction in its intake; is its air temperature sensor dirty—there is a dedicated cleaner for that; is its electrical connection compromised, does the movement of its internal vane appear to drag or is the movement unregulated?
Diagnosing an ailing Brick should be an orderly process of system-by-system investigation. Preconceptions and assumptions made without sufficient depth of experience can stall resolution. It can be tedious but it should be focused. Appearances can be deceiving.
Offline Lbxpdx
« Reply #49 on: September 07, 2023, 12:19:55 PM »
Can I use Air Mass Meter cleaner on the air temp sensor?
I’m wondering if the barn door moves when the bike is on its side.
My school day just started, so I’ll be checking stuff when I get home tonight.  I think I’m going to pull the pump and lines from the tank and check them again too.
  • Portland
