Author Topic: New law for riders in Illinois  (Read 6785 times)
RockyMountainRider
« on: December 29, 2011, 10:11:40 PM »
On Jan 1, 2012, a new law comes into effect in IL:
Motorcyclists stopped at a red light may proceed through if it fails to change to green after a reasonable length of time.
Effin eh as we used to say growin up in Canada.
Every state needs this law.
I remember sitting at a red light for about 5 minutes once and just before I said screw it and rode thru the red, a cop pulled up behind me.
So we both sat there for a few more minutes, until I turned around and gave him the wtf look.
So what does he do in response?  He drives thru the red himself, leaving me stranded.
I waited till he was out of sight and rode thru the red myself, chuckling.
Re: New law for riders in Illinois
« Reply #1 on: December 29, 2011, 10:25:53 PM »
yawl bro...
i pull onto the trigger... set the moto down on the side stand for 10 seconds... if i dont get the light in the next cycle i roll...
Offline motodude
« Reply #2 on: December 30, 2011, 01:28:25 AM »
I've found that rolling onto the trigger (usually a circle cut into the asphalt around here) about 1/3 of the way across (left to right) and then roll the bike up and back a couple of feet a couple of times usually gets the light to turn in its normal rotation.
That has worked virtually every time I've tried it.  Maybe they would have turned anyway but there is one intersection where I used to have to wait for someone coming the other way before the light would turn.  Rolling up and back appears to make it turn normally.
That being said, I have no clue if there's a law like that in OR or not but I've turned left LOTS of times on red (when it was safe to do so, of course) and never had an issue with an LEO.
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
« Reply #3 on: December 30, 2011, 07:31:31 AM »
some places now are using/changing over to more optical sensors mounted up by the lights instead of the current loops in the street.
Offline DRxBMW
« Reply #4 on: December 30, 2011, 08:27:04 AM »
Pennsylvania has had the above law in effect for the last twenty years. Problem is defining a reasonable & prudent amount of wait time in court, if you get popped by an LEO for the offense.
Adding magnets to your boots or underneath the frame does work.
Greenlight Trigger is the commercial product available for sale.
http://www.casporttouring.com/optimizer/category/GreenLight.html
Step 1: The Problem
If you or someone you know owns a motorcycle, a scooter, or even a small car, you've probably noticed that it's easy to get stuck in traffic lights. Well, I'm going to explain why it happens, and show you a great little trick that will save time, gas, and frustration, by getting you a green light every time.
Step 2: The Explanation
At most traffic lights and turn signals you'll notice a loop of wire buried in the pavement of the road near the stop line. This is called an "Inductive-Loop Traffic Detector" that operates by sensing a change of frequencies in the electric magnetic field over the coil of wire. In other words, when a car pulls up it senses a vehicle, and the light changes. Though most motorcycles, scooters, bicycles, and small cars don't really have enough conductive material to trigger these loops and change the traffic light.
Step 3: The Trick
Here is the simple scientific trick so you will never get stranded in a traffic light again. I picked up two very strong Neodymium Magnets that have a pulling force of over six pounds each. I also bought a roll of heavy duty exterior mounting tape. After cutting off a small strip of tape, I attached it to the magnets, then I applied it to the bottom of our test scooter. perpendicular to the road, and IT WORKED! These strong magnets produce a very powerful field that increases the inductants in these traffic sensors, and causes the light to change.
Step 4: The Tips
I decided to put the magnets inside a chrome plated pill holder that has a nice rubber "O" ring, so the magnets don't rust. Save time, gas, and frustration by using magnets to get you through traffic lights.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
