I searched the forum and didn't see anything like this so maybe someone here has experienced this already.
My gas cap was hard to latch in the closed position. Key moves freely in the locking mechanism. I bought the OE rebuild kit and swapped everything around thanks to the Harris video. Thoroughly cleaned and everything went back together fine. I even used a smattering of anti seize on the touch points of the pop out latch. It's still kind of a struggle to push hard enough down on top to get it lock closed. (pop out and clear the edge of the mount) Don't know why and can't figure out where the interference is coming from. The three screws through the foam gasket are about as tight as I dare to go so, can't really compress it any further. The odd part is too, is my cap has an additional spring and valve in the "domed" part of the cap that you have to pop off with pliers. The one in the video and the OE parts fiche doesn't show that part of the assembly at all.
So, I'm wondering what that is (pressure relief valve)?
Also, do you think it would help if I added three thin stainless washers to the filler neck shield to move it down slightly and then allow the dome to drop a little further and hopefully latch easier?
