Author Topic: Lower bushings causing fork seal leaks  (Read 2823 times)
Offline ckp
« on: April 15, 2023, 03:21:51 PM »
Long time no post....
My fork seals have been leaking for a long time. I've replaced them a few times with BMW and aftermarket and it got to the point the left one was really bad. Couldn't understand it as the bushings looked okay. About a year ago I took them apart again and found the inside of the lower bushings to be worn. I replaced the lower bushings and seals and there are no signs of leakage after a year. Might actually have it fixed. Thought someone might benefit.
* bushings.jpg (109.01 kB . 640x480 - viewed 316 times)
  • St. Louis, MO
  • 1996 K1100RS, 2001 KTM 520 EX/C, 1993 XR80, 2012 KTM 250SX
Re: Lower bushings causing fork seal leaks
« Reply #1 on: April 15, 2023, 03:33:37 PM »
I haven't looked at my fork internals for a long time.  What should we be looking for?
So far so good as far as leakage.  I run boots on all my bikes.
Offline ckp
« Reply #2 on: April 15, 2023, 04:44:32 PM »
Well mine were leaking, so there was something wrong. You're more informed than myself and I figure "if it ain't broke, don't fix it" might apply.
  • St. Louis, MO
