Selling Ilsa my 1994 K75RT horizon chaser. Time marches on and my touring days are over. She has 99,680 miles and runs perfectly despite a bit of noise from the balance shaft that has been there since I got her with 54,000 miles. Bike has been very well maintained and I was planning on a 9,000 mile trip to Alaska before having to change plans. I wouldn't hesitate to jump on it today to ride to the West Coast.
DSCN3299.JPG (51.62 kB . 768x576 - viewed 994 times)Many maintenance items have been addressed:
Clutch splines lubed
Drive shaft splines lubed
Ignition and gear position switches refurbished
All fluids replaced engine, trans, final drive, forks, coolant
Brakes bled and fluid replaced
Valves adjusted and matched for all cylinders
Spark plugs
Lubed throttle and stands
Cleaned all electrical connections
Serviced starter motor
Replaced injector filters, o-rings, and pintle covers
Rear master cylinder(2015)
Steering head bearings(2022)
Fuel pump(2015)
Rear main seal and clutch o-ring(2017)
Z tube(2018)
Fuel lines(2017)
Fuel and air filter(2018)
Monkey nutz(2018)
Brake pads(2017)
Vacuum port caps(2018)
Headlight bulb(2021)
Timing Chain(2017)
Upgrades:
Cartridge fork emulators and fork springs(2021)
Rancho fork boots(2014)
LED Parking light strip(2014)
LED driving lights(2014)
LED's in instrument cluster(2015)
Brake light upgrade with additional lights(2014)
GPS(2014)
Euro headlight switch(2014)
Fuel cooler(2016)
Engine protection bars(2016)
Outlet and control for heated jacket(2017)
12 hour clock modification(2015)
Turn signal running lights(2014)
Spal cooling fan(2015)
Stainless fasteners(2016)
Works Performance rear shock(2017)
3 spoke wheels(way easier to clean!)(2019)
K1100 center stand(2015)
Expanded tool kit with socket set and Allen wrenches(2016)
Short windshield for summer riding
Tank Bag
22 liter top case
City cases
Gen 3 tragkorbs
Rescue box with many spares for repairs far from home
A large number of K75 spares
New Shinko Tourmaster tires(unmounted, front and rear)
Spare mirrors
Spare lower fairing panels
Rear crash bars for City Cases(police equipment, super rare)
Mystic red paint
Rescue box:
Hall sensor plate
Fuel pump
Coil
Spark plug leads
relays
Temp module
Bulb monitor
Starter relay
Thermostat
Ignition module
Coolant pressure cap
Z tube
Bike would be a good candidate for a fly and ride. I could ship the rest of the stuff.
Asking $2750 for the whole mess.
