Author Topic: What are the minimum requirements for the ecu to operate  (Read 29796 times)
Offline Jon72
« on: February 18, 2023, 11:57:25 AM »
I bought a 1995 k1100lt and am in the process of building a cafe racer I need to know what I need to keep in the bike for it to run I will be using a m-unit blue for lighting and controls I'm just not sure about what inputs the ucu needs
  • Texas
  • 1995 k1100rs
Offline Jon72
Re: What are the minimum requirements for the ecu to operate
« Reply #2 on: February 18, 2023, 12:41:22 PM »
So if I supply power to the 15 pin and power the fuel pump it should run?
  • Texas
  • 1995 k1100rs
« Reply #3 on: February 18, 2023, 01:55:46 PM »
The brown/blue wire from the side stand switch needs to be grounded to that the Motronic relay sends power to Pin 33 of the Motronic.
Offline Jon72
« Reply #4 on: February 18, 2023, 03:24:23 PM »
Will I need power supplied to the green and green black going to the coils and injectors
  • Texas
  • 1995 k1100rs
Offline lewisnort
« Reply #5 on: February 21, 2023, 09:16:13 AM »
Hi Jon, I’m also doing an LT (1998) using an munit blue.
I have a wiring diagram made up where I’m only keeping the engine management loom, i.e. motronic plug to the sensors and injectors and such. The rest will be hand made.
If it works and I can get it running soon I’ll let you know and I can send it to you if you want.
  • UK
  • 1998 K1100 LT
Offline Jon72
« Reply #6 on: February 23, 2023, 07:28:14 PM »
I would greatly appreciate it
  • Texas
  • 1995 k1100rs
Offline Jon72
« Reply #7 on: February 28, 2023, 07:31:35 AM »
The handle bars and rear sets came starting to build
  • Texas
  • 1995 k1100rs
Offline lewisnort
« Reply #8 on: March 07, 2023, 04:37:47 AM »
What bars are you using and which bar controls are you planning to use? I’m going to run clip ons and have 2 3 button motogadget controls. It’s my first time working on a bike in this way so I’m not sure where I would get a throttle from since the original has buttons integrated. Do you have an email address I can send the wiring diagrams to? Sorry not had chance to test it yet, way too freezing in the uk for me at the moment.
  • UK
  • 1998 K1100 LT
Offline Jon72
« Reply #9 on: March 08, 2023, 11:12:33 PM »
I also have 2 3button controls my email is jonathandonnelly72@gmail.com
  • Texas
  • 1995 k1100rs
Offline Jon72
« Reply #10 on: March 08, 2023, 11:14:35 PM »
I'll be running just a basic cable throttle and the handlebars I got are from cafe4racer.eu they're bolt on as well
  • Texas
  • 1995 k1100rs
Offline Jon72
« Reply #11 on: September 04, 2023, 02:05:28 PM »
Ok I have the motogadget wired up and I'm not getting spark any ideas
  • Texas
  • 1995 k1100rs
« Reply #12 on: September 04, 2023, 02:39:26 PM »
Is the side stand up?
Offline Jon72
« Reply #13 on: September 05, 2023, 07:20:43 PM »
There's no safety switches hooked up right now they're all bypassed
  • Texas
  • 1995 k1100rs
« Reply #14 on: September 05, 2023, 10:26:31 PM »
It's really hard to give you advice since we have no clue what you've kept and what you've discarded from the original loom in your effort to switch to the Motogadget.
The spark comes from the ICU.  You'll need switched power, ground, HES inputs, and start button signal.  Have you got those?
Offline Jon72
« Reply #15 on: September 11, 2023, 04:58:16 AM »
I think I have all of those I can get it to fire and stay running for under a minute then it dies out I'm thinking oil pressure switch or coolant temp since those aren't hooked up I don't know where to run them to
  • Texas
  • 1995 k1100rs
« Reply #16 on: September 11, 2023, 07:22:56 AM »
Are you absolutely sure the fuel pump isn't dropping out when you release the start button.  I say this because the fuel system holds enough fuel to run the engine for about a minute at idle without the pump.
You might want to get a fuel pressure gauge to see what the the pressure is doing in the rail after the engine starts.  I think you can borrow or rent one at AutoZone.
Offline Jon72
« Reply #17 on: September 11, 2023, 08:29:23 AM »
I just replaced the fuel pump and cut the wire and am holding it on the battery to guarantee the pump is running
  • Texas
  • 1995 k1100rs
Offline Jon72
« Reply #18 on: September 11, 2023, 08:32:21 AM »
Does the iol pressure switch need to go to the icu
  • Texas
  • 1995 k1100rs
« Reply #19 on: September 11, 2023, 08:34:19 AM »
The oil pressure switch just lights up the idiot light on the cluster to let you know there is no pressure.  It has nothing to do with the operation of the engine.
Offline Jon72
« Reply #20 on: September 11, 2023, 09:00:55 AM »
What else would be causing short run time HES?
  • Texas
  • 1995 k1100rs
« Reply #21 on: September 11, 2023, 12:54:20 PM »
What might be helpful is for you to post clearly legible diagrams, with wire color labels, sufficiently large enough to show all wiring connections—and their sources—for input and output at the Motogadget instrument and M-unit. Was this video your inspiration?
Offline Jon72
« Reply #22 on: September 11, 2023, 01:59:17 PM »
This is how it's wired except I don't have a dash the fan isn't hooked up yet and the fuel pump is direct and the hand controls are wired using a mo button
  • Texas
  • 1995 k1100rs
« Reply #23 on: September 11, 2023, 03:09:19 PM »
How about showing the Motronic pin numbers for each wire?
Offline Jon72
« Reply #24 on: September 11, 2023, 04:16:25 PM »
I'm not sure where I would get that information
  • Texas
  • 1995 k1100rs
