Repair Guidance
K75 Running on 2 at idle and 3 when above 1500
Topic: K75 Running on 2 at idle and 3 when above 1500 (Read 2068 times)
Steveo277
Curious
January 05, 2023, 09:17:39 AM »
Hey all,
So I have my K running after 5 years of rebuild and it runs beautifully above 1500 but at idle she only runs on 2.
It has new coils, plugs, changed both ICU's, new injectors, fuel lines. It runs at 36 psi fuel pressure.
It has me stumped.
Woking
K75
Steveo277
Curious
Re: K75 Running on 2 at idle and 3 when above 1500
Reply #1 on:
January 05, 2023, 09:19:51 AM »
Forgot to add a picture of my bike.
Woking
K75
Laitch
Faster than a speeding pullet
Administrator
Reply #2 on:
January 05, 2023, 11:32:38 AM »
Do a noid test on #2 injector electrical connection to determine if that's the source of the intermittent problem. If the light isn't flashing at idle but flashes at higher revs, there's a wiring connection problem to that injector. This video explains the procedure. As mentioned in the video, noid kits possible can be gotten at major auto parts stores but you only need the light for Bosch injectors.
Along the Ridley in Vermont.
1995 K75 89,000 miles
KCinSB
^ Proficient Motobricker
Still learning about Bricks from this site!
Reply #3 on:
January 05, 2023, 11:12:46 PM »
Since I’ve never seen a Noid tester, or know what a Noid is, I started to ask how you know its only running on #2 at idle,……. But reading again, I think you mean it is only running on 2 of the 3 cylinders correct?
Santa Barbara, CA
SOLD
Chaos
Administrator
Mars needs women!
Reply #4 on:
January 06, 2023, 01:34:44 AM »
Compression test?
sw ohio
1987 K75S VIN 0231
Martin
Reply #5 on:
January 06, 2023, 03:00:38 AM »
From a cold start the header pipe of the non-firing cylinder will be colder to touch as it warms up. You can also use a laser temperature gun which is a worthwhile addition to any tool kit.
North Lakes Queensland Australia
1992 K75s Hybrid, Lefaux, Vespa V twin.
frankenduck
Adrninistrator
Reply #6 on:
January 06, 2023, 04:21:41 AM »
If you've replaced all of that stuff and swapped th ICU and L-Jetronic then the next link in the chain is the FI wiring harness - 61111459978. Do you have a spare one of those to try?
New to K bikes?
Click here.
K Bike Maintenance & Mods:
Click here.
