Author Topic: turbo project  (Read 18682 times)
Offline 85killzillaRS
  • BumbleBrick
turbo project
« on: December 14, 2022, 04:51:48 PM »
85 turbo project
 have the exhaust, turbo, plenum, injectors, fuel pressure reg, vac manifold
need to hook up hot and cold sides, oil feed, return pump, water inter cooler
& quite a few other details  ;-)
* l.side.jpg (58.55 kB . 320x228 - viewed 1821 times)
* td025.jpg (44.33 kB . 240x320 - viewed 1860 times)
* view.jpg (21.41 kB . 320x265 - viewed 1827 times)
* seat.jpg (16.42 kB . 240x320 - viewed 1866 times)
  • El Paso, TX
  • 85K100RS
Christopher
past- 68 BenelliDynamo, 74 HodakaAce100, 76 BultacoMatador250,
85 HondaNighthawk650, 83 HondaCB1100F, 90 KawasakiZX10
Someday ϒll get a bike from this century (no hurry)
Offline KCinSB
Re: turbo project
« Reply #1 on: December 23, 2022, 11:12:26 AM »
Wow!! 😵‍💫 not a project for the faint of Heart!!  Nice work so far! Looks like you are building a K-Rocket!
  • Santa Barbara, CA
  • SOLD
  • BumbleBrick
Re: turbo project
« Reply #2 on: December 25, 2022, 02:21:44 AM »
 :mb: it's a winter project, i'll try to ride it again by next winter ;-)
  • El Paso, TX
  • 85K100RS
Christopher
Offline Arktasian
Re: turbo project
« Reply #3 on: December 30, 2022, 12:00:53 AM »
Excellent, almost didn't notice this (up in the special section)
Do you have plans to manage fuel/ ignition? Charge air cooler? Edit: just noted you have that on your menu.
I'm rather tardy with my project - it awaits final wiring but life has thrown some family weddings into the mix and that also drives more home reno work.
I've chosen a similar location but have opted to run original exhaust manifold as showing on below attachment. Also, that will provide heat to a bike that has a reputation already for being hot, so I've opted for marine grade heat blankets and a ventilating air system that comes off my A to A. (SS wire used to sew those guys).
Cheers and good luck.
* IMG_2094.JPG (46.69 kB . 768x576 - viewed 2157 times)
* IMG_6446.JPG (42.2 kB . 768x576 - viewed 2172 times)
  • Abbotsford
Offline RoyalWaffles
  • Rebuild in progress
Re: turbo project
« Reply #4 on: April 10, 2024, 07:17:56 PM »
Heyo, Do we have an update on this project? What have you learned? And have you found the limits of the stock internals for the engine/drivetrain?
  • Ontario
  • Honda Cb650F and this '86 K75C I found
I found a abandoned 1986 K75C in a treeline on my way back from wendy's and now I'm trying to bring it back to life
Tags: winter project
