Author Topic: K75RT Electrical Help  (Read 2664 times)
Offline JD!
« on: July 15, 2022, 02:27:54 AM »
Hi,
I have a 1993 K75RT that the previous owner clipped all the leads short when he discarded the front fairing.
I'm a shite electrician and need help ID'ing a pair of leads. They come off the loom along with the leads to the left blinker.
From what I can tell squinting at my Clymer's, the leads (green/blue (G/L), and brown) are part of the bulb monitoring system. They don't seem to show any voltage when the ignition is on.
I'm going to run aftermarket lights, so do I need to do something with the mystery leads?
Cheers
Jim
  • South Island
  • Pieces of a K75RT
Re: K75RT Electrical Help
« Reply #1 on: July 15, 2022, 07:06:08 AM »
As far as I know, the K75RT only has two horns, two turn signals, a head light and parking light in the fairing.  If your headlight, parking light and turn signals work, the remaining wires probably go to a horn that may have been removed by the previous owner.
« Reply #2 on: July 15, 2022, 10:39:21 AM »
Here's the Clymer wiring for the BMU. It has no green/blue wires.
On a stock K75:
Green/blue wires come from the load shed relay and provide lighting power to the right combination switch (headlight/parking light switch) and left combination switch(flash to pass) as well as power to the #7 fuse. The #7 fuse sends power to the following via green/brown wires:
Flasher relay
Alarm connector
Horn relay
Thermo relay (for radiator fan)
There is no green/blue wire that goes directly to any of the lights. (or horn)
All brown wires are ground.
« Reply #3 on: July 15, 2022, 02:29:51 PM »
Here are schematic color renditions from Clymer for 1990 and on. You might be looking at the flasher unit because it is depicted in the unit's diagram below as having a G/B wire. The turn signals aren't part of the bulb monitoring scheme.
Offline JD!
« Reply #4 on: July 15, 2022, 06:26:27 PM »
Bingo! Looking at the somewhat faded wires, my mystery lead has the same colours as the known horn lead, G/GR, not light blue as I thought at first.
Voltmeter confirms voltage when horn button is activated.
One confusing thing is the remaining horn was mounted on the frame, near the radiator on the right side. I didn't realize that there should have been two horns. Another PO kluge, evidently.
Thanks for the help.
Jim
  • South Island
  • Pieces of a K75RT
« Reply #5 on: July 15, 2022, 10:14:43 PM »
You're welcome!  Glad you got it figured out.
Offline JD!
« Reply #6 on: July 16, 2022, 07:04:04 PM »
Any link to the schematic in colour? My Clymer is black and white.
Jim
  • South Island
  • Pieces of a K75RT
« Reply #7 on: July 17, 2022, 01:46:10 AM »
Jim
Try this link from my Google Drive:
https://drive.google.com/file/d/0B3UPbNZRyr1raHpPeUpUeGkxM2M/view?usp=sharing&resourcekey=0-z22TceR1coe9t0c54qQeYg
Offline JD!
« Reply #8 on: July 19, 2022, 11:26:53 PM »
Downloaded a copy. Many thanks! It will be a valuable document during the project.
Cheers
Jim
  • South Island
  • Pieces of a K75RT
