Author Topic: Show me your K1100RS wind Deflector Vane fix..  (Read 2898 times)
Offline KCinSB
« on: June 01, 2022, 12:58:24 PM »
  I expect there are others faced with the dreaded broken Air Deflector Vane Tabs, as shown here. Yes, they can be bought new, at +/- $200, but wish to avoid the poor OEM design that will likely break again! Has anyone here come up with a way to hold the vane in position?  After trial rides to figure out where it works best, how have you held it in that position? At the moment, I have small rubber bushings at each end to help center the vane. I am looking for a way to hold the vane firmly, and realize the method used may not be pretty! Does anyone here care to show their fix?    🛠.
  • Santa Barbara, CA
  • SOLD
Offline KCinSB
Re: Show me your K1100RS wind Deflector Vane fix..
« Reply #1 on: June 20, 2022, 10:45:11 AM »
So far no suggestions.
 It’s been 2 weeks of random thinking which span overly complicated designs, and then Tape, I have settled on a simple idea. Not terribly noticeable or ugly, it seems to work OK, and allows change if required. Likely will not.
Started out overly involved, ended up simple:
  • Santa Barbara, CA
  • SOLD
« Reply #2 on: June 20, 2022, 04:54:20 PM »
Nice.
Offline AtLarge
« Reply #3 on: June 20, 2022, 08:11:24 PM »
Brilliant KC. Having already glued one of mine I might try two just to spread the pressure out.
  • IA
  • 1994 K1100RS
« Reply #4 on: June 21, 2022, 02:50:58 PM »
Good fix. icon_cheers
Not sure why BMW made that part adjustable. In my experience the only worthwhile position is tilted all of the way forwards.
