Author Topic: Will the bike start with a push  (Read 4740 times)
Offline Steviescumbag
« on: May 25, 2022, 02:03:14 PM »
Hey, in Addition to one of my last topics.
I’m wondering if I can push the bike to a start (if someone pushes me) if I’m having electrical whack on start up which I’m convinced is a grounding problem. Just so I can get it home
Thanks
  • Toronto, Canada
  • 1992 bmw K75 Rt
Re: Will the bike start with a push
« Reply #1 on: May 25, 2022, 05:28:54 PM »
The only way to find out is to do it.
« Reply #2 on: May 25, 2022, 06:14:59 PM »
Yes. (But rolling it downhill is easier.)
I wouldn't try to bump start it yourself. Sit on the bike and have someone else push.
Offline Past-my-Prime
« Reply #3 on: May 25, 2022, 06:42:24 PM »
You aren't using the starter so don't need a lot of juice, but you DO need some: for the fuel pump and electronics and sparks.
I have started mine rolling it downhill when the battery was _almost_ dead.
« Reply #4 on: May 25, 2022, 07:36:04 PM »
I've been able to bump start mine but it does need enough juice for the pump and plugs
Offline Duckbubbles
« Reply #5 on: May 26, 2022, 08:52:47 AM »
Put it in 2nd or maybe even 3rd gear as trying in 1st will probably just slide the rear tire.  And yes, a downhill or someone to push as you sit on the bike is best.
Frank
  • Austin, Texas USA
  • 1985 K100/1100RS
'23 R1250RS
'03 R1100S BCR #6/200
500,000+ BMW miles
« Reply #6 on: May 26, 2022, 01:04:20 PM »
I’m wondering if I can push the bike to a start . . .
Yes
I recommend the Max-velocity, bum-start method as depicted in video below. In any case, please have somebody make a video of your result so it can be placed in Motobrick.com's instructional archives.
« Reply #7 on: May 26, 2022, 01:42:46 PM »
Lol okay good to know. But yea I wouldn’t want to try with bump start. The brick is too top heavy. Lol
  • Toronto, Canada
  • 1992 bmw K75 Rt
« Reply #8 on: May 26, 2022, 06:54:59 PM »
Absolutely.  Find a strong person to push you, or a long gradual downhill road.
« Reply #9 on: May 26, 2022, 09:03:06 PM »
And third gear. I agree with that.
« Reply #10 on: May 26, 2022, 09:21:00 PM »
Steep hills work fine too.
« Reply #11 on: May 27, 2022, 07:31:59 AM »
Just not too steep
« Reply #12 on: May 27, 2022, 08:30:47 AM »
Slightly too steep is still OK if you're extra careful.
« Reply #13 on: May 27, 2022, 10:52:19 AM »
Just not too steep
When I lived in Seattle I had the steepest hill in the neighborhood at the end of my alley. (Seattle has lots of hills.) I used it several times over the years to bump start. I prefer a steep hill because it takes much less time/distance to get up to speed for a bump start. You do need to feather the clutch when doing any bump start but that's a pretty basic riding skill.
