Author Topic: 1993 K75 fuel level float o-ring  (Read 2906 times)
Offline sci
« on: May 17, 2022, 09:50:21 AM »
Hello guys,
I have a 1993 K75 and developed a leak from under the fuel tank. I’m 99.9% it is the fuel level float o-ring and I have ordered a new one. My question is; I can cut the old one out but the new one will never stretch over the base of the float assembly. Has anyone replaced this o-ring and how did you do it?
Thank you,
-Dan
  • Battle Creek, Nebraska
  • 93 K75
Re: 1993 K75 fuel level float o-ring
« Reply #1 on: May 17, 2022, 10:47:34 AM »
Hmmmmm...  I have replaced a couple of those o-rings, and now that you ask, I can't recall how I did it.  I do know that it wasn't difficult.  I think it went over the float and the sender, but can't say for sure.
« Reply #2 on: May 17, 2022, 05:25:39 PM »
Empty and remove the tank. Remove the fuel filler cap assembly. Disconnect the wiring to the fuel pump. Remove the four Phillip's head mounting screws, be careful not to strip the heads. Once the screws are removed with a bit of wangling the sender unit can be removed. It helps to observe with a torch which way you have to orientate the sender as you remove it. Remove the old "O" ring and fit the new one making sure as you reassemble it that the "O" ring is properly seated. A small dab of silicone grease can help keeping it in place. Tighten the screws evenly.
« Reply #3 on: May 17, 2022, 06:56:19 PM »
In the US we call a flashlight a flashlight, not a torch. A torch is something that spews fire. :laughing4-giggles:
« Reply #4 on: May 17, 2022, 07:25:18 PM »
And, what's wrong with spewing fire???? And I also refuse unconditionally to speak or spell American.
« Reply #5 on: May 17, 2022, 08:00:28 PM »
In other words, and a shaky memory, remove the sender, place the o-ring in its location on the outside of the tank, then replace the sender. Therefore it doesn't have to be stretched over the base.
With the tank upside down on something soft to protect the paint, if you feel any resistance when installing the sender, stop. Look to make sure the float isn't on the wrong side of the drain pipes or other obstructions. Make sure the o-ring contact surfaces are clean and smooth.
Offline sci
« Reply #6 on: May 18, 2022, 12:45:11 PM »
Thanks Gryphon, frankenduck and daveson. I got hi-centered at work yesterday. Martin, I knew exactly what you meant and love the irony. Keep up with that accent. I enjoyed it.
-Dan
  • 93 K75
Tags: float o-ring
