Author Topic: k100 misfire judder  (Read 2098 times)
Offline shandybills
k100 misfire judder
« on: May 08, 2022, 01:58:07 PM »
My 1988 k100 has a misfire on tickover sounds like a clunk and the revs drop for a split second, also seen when balancing TB  the gauges drop like a missed beat, Initially had a dud coil replace with a second hand one all cylinders running but still have the misfire, When riding it seems a bit boggy or fluffy or holding back. Thinking it could be hall sensor or coolant temp sensor. Any help guys.
  • UK
  • K100
Re: k100 misfire judder
« Reply #1 on: May 08, 2022, 02:36:30 PM »
How old is the fuel filter? Have you checked the tank fuel hose connections for tightness? Does the crankcase breather hose have splits in it?
Offline shandybills
« Reply #2 on: May 08, 2022, 05:11:53 PM »
just took the hall sensor off and looks like someones done some soldering bodge in it the solder joints were not insulated so assuming this could be the problem
  • UK
  • K100
« Reply #3 on: May 08, 2022, 11:08:44 PM »
 icon_cheers
Offline shandybills
« Reply #4 on: May 11, 2022, 04:59:58 PM »
Changed plugs, leads, One coil changed as was only running on 3 now all 4 work. Changed the Hall pickup trigger sensor and not cured the problem, if i take a vacuum cap off i can see a flash down the hole when it misses a beat
  • UK
  • K100
