Author Topic: How Difficult Is the Spline Lube?  (Read 4276 times)
Offline PickledBrick
« on: May 05, 2022, 03:41:28 AM »
I have the 90' k75rt in blue with 50,000 miles. Just purchased. How difficult is the spline lube job ? I intend to change all fluids, fairing, shock and headlight.
  • Bay area
  • K75Rt, F650GS, triumph trophy
Re: How Difficult Is the Spline Lube?
« Reply #1 on: May 05, 2022, 07:56:22 AM »
It's mostly a nut-and-bolt operation. You'll need tools, patience and a workplace with room enough for the rear drive, swing arm and transmission. You'll also may need Liquid Wrench and a heat gun. It's all broken down by Chris Harris here.
« Reply #2 on: May 05, 2022, 08:34:15 AM »
It's mostly a nut-and-bolt operation. You'll need tools, patience and a workplace with room enough for the rear drive, swing arm and transmission. You'll also may need Liquid Wrench and a heat gun. It's all broken down by Chris Harris in this video but you don't need a hydraulic lift; sawhorses will do.
I've done dozens of clutch spline lubes and never had any need for either Liquid Wrench or a heat gun.
And you only need one sawhorse.
« Reply #3 on: May 05, 2022, 08:57:36 AM »
  :laughing4-giggles:
« Reply #4 on: May 05, 2022, 09:32:50 AM »
I believe Michaelovich has proven that a surface of block pavers is a more elegant and effective medium for dismantling a Brick than working while seated in a quarter-lotus position on gravel, and having somebody just hold the rest of the moto while you work not only saves lumber but provides companionship. Furthermore, use of a dog's tail to remove dust and other particles from the work area is also useful. There are many alternatives, Pickled Brick.  :laughing4-giggles:
Offline alexg
« Reply #5 on: May 05, 2022, 07:52:51 PM »
Not trying to highjack the thread, but ...
My bike has a little over 15k miles, but it is still 29 yrs old. Do I need to do the lubing of the clutch spline? I have done the rear spline only when I bought it 5 years and 5k miles ago.
Thanks for the suggestions.
  • Michigan
Alex G.
« Reply #6 on: May 05, 2022, 11:24:16 PM »
Concerning shaft spline maintenance, attached is an extract from BMW's service checklist. 40K is what I follow for the transmission input shaft; I clean and re-lube the rear drive splines every tire change.
« Reply #7 on: May 05, 2022, 11:50:37 PM »
Clutch splines can be lubed by supporting the transmission on a pair of the longest M8 bolts you can find.  Mine are about 125mm long.
Put one in on each side of the transmission so you can slide it back from the engine far enough to to see the output shaft splines.  About an inch and a half is good.  Then you can use a metal handled parts brush stuck on the shaft of a screwdriver or a 1/4" dowel to reach in and put the lube on the splines.  There's no need to completely remove the transmission if there are no oil leaks at the o-ring or the rear seal.
« Reply #8 on: May 06, 2022, 06:02:37 AM »
I would. I clutch spline lube every new-to-me K bike right when I purchase it.
If you start getting false neutrals shifting from 4>3 and/or 3>2 then that it usually a symptom that the clutch splines are dry and wearing.  If you're experiencing that then definitely lube the clutch splines as soon as is convenient.
« Reply #9 on: May 06, 2022, 06:17:47 AM »
My 1990 K75RT completely stripped the clutch splines at 36K. (Conveniently stranding me 1,200 miles from home.)
This was back when I was a Knoob and did not know that the downshifting false neutrals I started getting at about 25K were a symptom of clutch splines needing lubrication.
On the bright side, I did get 11K miles from when they started getting "dry" until they completely stripped.
Offline alexg
« Reply #10 on: May 06, 2022, 08:41:18 PM »
Thanks for all the replies. Will consider doing a bike-wide spline lube in the winter. Even though the miles are not there, cannot believe the spline grease would not have hardened in 30 years, decreasing the lubrication performance.
  • Michigan
Alex G.
Offline milq
« Reply #11 on: May 13, 2022, 04:36:55 PM »
I don't fold up like that!
  • Southern IL
  • 1988 K75S
« Reply #12 on: May 13, 2022, 05:26:20 PM »
If you are getting false neutrals when downshifting than I'd do it sooner rather than later.
Offline alexg
« Reply #13 on: May 13, 2022, 05:52:05 PM »
For now it is working flawlessly. Thanks !
  • Michigan
Alex G.
« Reply #14 on: May 13, 2022, 06:43:01 PM »
Molybdenum is classified as a dry lubricant. The paste containing it is used to carry it onto the surfaces of the splines where the molybdenum in the paste then bonds with the metal and fills imperfections in its surfaces as the the shafts start engaging during engine operation. The carrier paste can dissipate. Moly's lifespan as a lubricant in this application doesn’t depend upon the length of time since it was applied but rather the length of time that the surfaces to which it has bonded have been engaged in operation with each other. In Bricks, that length of time is measured in miles of operation.
Offline alexg
« Reply #15 on: May 13, 2022, 08:12:54 PM »
Good, then maybe in 2024 I will lube those splines.!
  • Michigan
Alex G.
« Reply #16 on: May 13, 2022, 11:14:10 PM »
We'll leave the light on for you.  112350
