Author Topic: Another speedometer issue  (Read 6215 times)
Offline kevinu
« on: April 20, 2022, 03:50:20 PM »
Just over 2 years and more than 13,000 miles into my K75 experience, I have this recurring issue:
The speedometer needle does not stay secure.  It appears that the mechanism that holds the needle vibrates significantly - this includes the odometer and trip mileage indicator.   When on bumpy surfaces, I can see these components vibrating and moving slightly.  The tachometer needle on the other side stays very solid and secure and does not vibrate in a similar fashion.  The result is that the speedometer needle sometimes swings to unreal speeds when on bumpy surfaces, sometimes loses the 0 mph position, or sometimes it completely falls off.  Can anyone comment on how solid their speedometer needle is relative to the tachometer needle?  Maybe I have something broken in the odometer/trip mile indicator area that makes it not fit as securely as it should.  Or maybe I am not pushing the needle on to the pine hard enough, but I have tried to fix this several times.
Thanks
  • Alpine, Texas
  • 1994 K75
Re: Another speedometer issue
« Reply #1 on: April 20, 2022, 04:03:00 PM »
Are all the screws that hold the mechanical bits behind the faceplate all tight?  Your description makes me think the meter movement is rattling around.
« Reply #2 on: April 20, 2022, 04:55:13 PM »
Check that the speedo sensor connector is clean and well connected. Under right side cover. Follow speedo sensor wire coming from final drive.
Offline kevinu
« Reply #3 on: April 20, 2022, 05:13:04 PM »
I just had it apart and checked that all screws are tight.  I agree that meter movement might be part of the problem.  Next I will check the sensor.
  • Alpine, Texas
  • 1994 K75
« Reply #4 on: April 20, 2022, 05:20:45 PM »
Here's the speedo connector in the cluster. You can undo the two mini screws, pull the connector out and twist the pins a little so that they make better contact.
Offline kevinu
« Reply #5 on: April 20, 2022, 05:45:22 PM »
Frankenduck: I see what you are talking about.  I will try that when I have it apart.
  • Alpine, Texas
  • 1994 K75
Tags: speedometer
