Author Topic: 92 k75 needs a short motor  (Read 8235 times)
Offline Selaeration
« on: April 05, 2022, 09:01:55 PM »
My 92 k75 broke a rod and went through the block.
Looking for an engine to remotor.
  • Ohio
  • K75s
Re: 92 k75 needs a short motor
« Reply #1 on: April 06, 2022, 09:07:03 AM »
should be easy to find one on Ebay or beemerboneyard.com.  Engines are usually the last thing that breaks on a K.
« Reply #2 on: April 06, 2022, 10:24:14 AM »
Be sure to get a 1989 or later motor - it will have the newer piston rings.
« Reply #3 on: April 06, 2022, 11:41:41 AM »
last time i threw a rod it was mystic rod...
Offline alexg
« Reply #4 on: April 06, 2022, 08:17:46 PM »
Do you care to elaborate on the event? Missed a gear or something totally unexpected? Those engines will go to 10000 rpm w/o much issue.
  • Michigan
Alex G.
« Reply #5 on: April 06, 2022, 08:44:25 PM »
I've seen a couple K engines grenaded by someone not realizing to old oil filter left it's rubber O ring stuck to the block and installed the new oil filter on top of it, leading to the stacked O rings blowing out and loss of oil pressure.
Offline Rcgreaves
« Reply #6 on: May 13, 2022, 02:29:24 AM »
I have a 1987 K75 long block salvaged after my 2016 crash that I scavenged for parts. head off, timing chain off.  Solid core. ( sooo No FI, no covers, no gearbox, no hall effect sensors,   $10 plus actual shipping cost to you FOB Livingston WI 53554  sixzero8 72six one5five 4 cell
Doing “better than I deserve"
« Reply #7 on: May 13, 2022, 05:38:20 PM »
Contact Larry:
http://specialks.net/
He's moving soon and I know he has some good K75 engine blocks.
Or try an email to partshaus@aol.com
Tags: engine motor
