Author Topic: need i stress? water drip after oil water pump overhaul  (Read 2550 times)
Offline foliver
« on: March 16, 2022, 08:50:31 PM »
Hi all.
well, 200 miles after the oil water pump overhaul ( including new shaft), i've seen yesterday, that after a ride of 12km ( i'm comunting that to work) while i open the garage i see in the floor some drips of water ( from the dedicated hole).
After this stain, no more leaks when parking.
I don't know if it leaks while driving.
It has been a long overhaul, need i stress about that?
ouch!
  • Montevideo, Uruguay
  • Bmw K75C 86
Offline Past-my-Prime
Re: need i stress? water drip after oil water pump overhaul
« Reply #1 on: March 16, 2022, 10:48:28 PM »
Foliver, lots of people have had to do the waterpump rebuild twice. I'm frankly amazed that I was able to do it just the once, and followed with a 600 mile day, a week or so later, without any leaks. It's not really easy to get that bearing/seal in completely straight. However, I understand that sometimes a little bit of coolant will leak initially and then stop on its own. How's your coolant level? If it loses a couple drops probably not a big deal. But I'm also a bit obsessive about some things so if it kept dripping, I'd give it another go. I know, not super helpful.
« Reply #2 on: March 16, 2022, 11:22:31 PM »
Si tus problemas no tienen soluciones, ¿por qué te preocupas?
Si tus problemas tienen soluciones, ¿por qué te preocupas?
:laughing4-giggles:
If the coolant level in the reservoir gauge drops and you need to mop the floor every day, you will need to spring into action. Until then relax; the seal will probably seat eventually.
Offline foliver
« Reply #3 on: March 17, 2022, 05:04:30 AM »
thanks for your answer Past, i know it's not an easy task, and the previous maintenance has let the internal surface a little scratched, i'll keep an eye on that and may be, as you said i'll give it another go, thanks!
  • Bmw K75C 86
Offline foliver
« Reply #4 on: March 17, 2022, 05:07:10 AM »
jajajajajajajaj!, you are right but the anxiety is difficult to drive.
I hope it will seat, in some days i'm going to make 600 km ( in 2 days)  so i'll stick a tape on the level just to be sharp about lost quantity.
thanks!!
  • Bmw K75C 86
