Author Topic: Battery leads,  (Read 2398 times)
Offline redwolfstudio
Battery leads,
« on: February 16, 2022, 07:00:00 AM »
etHi everyone,
So, here I am slowing putting my K75 RT project back together and about to place the battery when I realized I forgot to pay attention where the neg goes?!?
Thanx for your help!
  • Sweden
  • 1990 K75 RT
Re: Battery leads,
« Reply #1 on: February 16, 2022, 08:04:00 AM »
Positive on the left, negative on the right.
Re: Battery leads,
« Reply #2 on: February 16, 2022, 08:27:47 AM »
The other end of the negative lead is attached to the transmission above the shifter.
If you want to be really anal about your grounds, you can make a #14 wire with ring connectors at each end and run it from the ground point on the frame under the fuel tank down to the ground point on the transmission.
Re: Battery leads,
« Reply #3 on: February 16, 2022, 09:43:50 AM »
Super! Thank you Mighty Gryphon :-))
  • Sweden
  • 1990 K75 RT
