Author Topic: Battery mounts rubber bobbin,  (Read 2336 times)
Offline redwolfstudio
« on: January 11, 2022, 05:04:00 AM »
Hi everyone,
I’m removing these battery plate holders, all rusty and one came off without effort. The others seem stuck. As you can see in the picture I ripped one off leaving something I have to remove.
Is there a trick here to remove them?
  • Sweden
  • 1990 K75 RT
Re: Battery mounts rubber bobbin,
« Reply #1 on: January 11, 2022, 05:56:31 AM »
I'd normally say they would unscrew, but it looks like you may have to carefully drill the center and use a screw extractor to get it out.
You might could try a skinny flat edge tool to bend the edges up, at which point you could possibly get some pliers to grip and remove it that way without drilling.
« Reply #2 on: January 11, 2022, 06:05:04 AM »
Thanx Scott. Yes the first one just pulled right out. The others just bend, its all rubber no shaft it seems.
Ok, will try :-)
  • Sweden
  • 1990 K75 RT
« Reply #3 on: January 11, 2022, 09:03:51 AM »
I used a sharp chisel to bend up the edge so I could grab it with Vise Grips.  Then I heated it with a torch and unscrewed it.  Easy!
