Author Topic: K100 starter motor seal dimensions?  (Read 3391 times)
Offline zdj355
« on: December 05, 2021, 01:31:50 AM »
Searched high and low and I'm a bit surprised I couldn't find an answer.
Does anyone know the dimensions for the seal in the front of the starter motor (not o ring)?
Measuring my broken one I got 25x15x5 or 24x15x5. Are either correct?
  • California
  • 1985 K100RS
Re: K100 starter motor seal dimensions?
« Reply #1 on: December 05, 2021, 07:49:11 AM »
My first guess would be for a 25mm o.d.  They are probably cheap enough that you could get one of each size to see which one fit best.  I would think that one would be too loose or too tight.
You could take the front housing of the starter to the bearing dealer to check the size.  That's what I would do.
« Reply #2 on: December 05, 2021, 09:44:51 AM »
Exactly this topic was discussed in the K100 forum a couple of weeks ago. Dai's advice in this post seems to be the way to go. Tell us about your Brick—the mileage on the odometer, the general appearance of its neglected state and what you know about its history.
Offline zdj355
« Reply #3 on: December 06, 2021, 12:46:07 AM »
No bearing shops nearby. I'll buy the 25 and report back so the info is out there. Thanks!
  • California
  • 1985 K100RS
