Author Topic: Wiburs Shock-how to run?  (Read 10630 times)
Offline 552255
« on: December 16, 2011, 01:33:22 PM »
Got a used Wilburs shock (630) and installed it, I am unfamiliar with the adjustments, although it looks straitforward.  Pre-load adjustment should be 1 inch? or so, (ie. on the bike, vs off bike)...and the dampener turns clockwise to increase/stiffen the rebound?  Looks to be a nice shock.  Any info appreciated.
Eric
'97 K1100LT
'97 K1100LT-SE
'96 k1100RS-SE
Re: Wiburs Shock-how to run?
« Reply #1 on: December 16, 2011, 01:56:08 PM »
« Reply #2 on: December 16, 2011, 02:04:47 PM »
greetings 552255...
welcome to motobrick.com...
did you get your wilbers 630 from ted in california or klaus in new jersey...
the bottom is to set your ride height and spring preload the top is to set your rebound dampening...
Offline CRASH
« Reply #3 on: December 17, 2011, 03:30:13 AM »
Setting preload for height and sag can be found on GOOGLE - adjusting sag on a motorcycle - the amount of initial sag and difference will depend on the amount of travel you have.  My late brick K goes for 1" unloaded and 1 3/4" with me on it.  The rebound, start off with it in the middle ... this is the default for Wilbur shocks from the factory.  You can adjust in more or less as you learn how it works.
If it is an older shock, consider a rebuild/service.  Should be done about every 25 to 30k miles and makes a huge difference.
- CRASH -
Offline 552255
« Reply #4 on: December 18, 2011, 01:41:02 PM »
Test rode yesterday and it is waaaay better than the stock shock.  The pre-load and dampening seems to be about in the middle of the ranges, and the bike rode super.  Will probably just leave alone, and after some use have it rebuilt, it seems to work great for now.  This and radial tires were the best money spent so far on this bike.
Thanks for info
Eric
'97 K1100LT-SE
'96 k1100RS-SE
Offline DRxBMW
« Reply #5 on: December 19, 2011, 08:01:47 AM »
101 on how to dial in, you really should measure the sag for starters.
I'm an Ohlin fan but to each his own. Considering a YSS on the GS after the Holiday's.
The first thing to do after you install your new shock is to set the ride height. This is
accomplished by adjusting the preload on the spring. You will need a helper to take measurements
while you do this.
First, with the bike on the center stand, measure the distance from the rear axle to some fixed
point on the frame. Next sit on the bike and while balancing as well as you can have your
assistant measure again from the axle to the same fixed point on the frame. Subtract the first
measurement from the second one. If the difference, called sag, is more than about 1.5" dial in
more spring preload until your sag measurement is between 1.25 and 1.5 inches.
Once you have the preload correctly adjusted, start riding the bike to get an idea where to go
with the damping adjustments. These adjustments are much more subjective than the preload and you
will have to ride the bike under a variety of conditions to get an all around idea of which way
to go.
Compression damping controls how quickly the shock can be compressed when the wheel encounters a
bump. Note the bike's behavior on sharp-edged bumps such as broken pavement and patched pot
holes. If it seems to bottom too easily, add more compression damping. Go back over the same
piece of road so that you can compare. If the rear end feels too harsh and you get the sense
that the suspension isn't moving very much, try backing off the compression damping.
My personal preference is to use as little compression damping as possible while still preventing
excessive bottoming. Rebound damping controls how fast the shock can extend after being
compressed. Again observe the bike's behavior under a variety of road surfaces, throw in a few
twisty roads as well. Try to sense the behavior of the rear end after traversing rolling bumps as
opposed to the sharp edged ones described above.
What you are looking for is rises and dips that create a large amount of suspension travel. Try
to determine if the rear end settles quickly or does it bounce a couple times? If you sense any
"floating" or "bouncyness" increase the rebound damping. This may come across as a wallow or
weave in fast cornering.
If you dial in too much rebound damping the shock may not be able to extend from one bump in time
to handle the next one. In the case of several closely spaced bumps the rear end can actually
pump down. Check this by running over a railroad track (or some other series of closely spaced
bumps) a few times at different speeds. I have a perfect spot not far from my house where there
are two tracks in parallel.
If after traversing a series of closely spaced bumps you have a sense that the rear gets lower
after each bump or if the last bump in the series feels much harsher than the first you may have
too much rebound dialed in. Back it off and try again. You won't be able to set it up all in one
day, more likely you will gradually dial it in over a period of several weeks. It's strictly a
trial and error process but when you get it dialed to your satisfaction, you'll know it.
Keep notes so that you don't end up going in circles and remember as a general rule, if you
increase your spring preload, such as when loading the bike up or carrying a passenger (remember
you should try to maintain that 1.25 -1.5" sag between unloaded and fully loaded) you should also
increase the rebound to control the additional preload.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
Offline 552255
« Reply #6 on: December 19, 2011, 01:49:10 PM »
Thanks for that great write-up, i'm gonna try and print it out!  Man, i didn't realize how technical a rear shock was, but you really can feel a difference.  The 630 only has the rebound adjustment, i see the better the shock, you can adjust both directions.   Can see why Ohlins, etc. are expensive hardware.
Here comes a storm on the plains--ahhh! Better get the battery tender out..
'97 K1100LT-SE
'96 k1100RS-SE
« Reply #7 on: May 20, 2012, 07:40:07 PM »
I would like to bump this excellent write-up back up because I found it so helpful.  I had bought a used Works brand shock last winter.  A previous owner had screwed it all the way in, I assume to make it shorter.   Even though H-Corn warned me of this problem when he sold it to me, I've been riding on it, as is, this spring.  Today I finally got around to adjusting the preload as described here by Gary and what a difference.
That's the ride I've been looking for!
Thanks.
