Author Topic: Extra leads inside the mirror housing on the fairing  (Read 3032 times)
Offline AtLarge
  • Not too many bikes. Garage too small.
« on: November 04, 2021, 02:25:20 PM »
Just to be sure... the extra wires are for running lights correct?  Can I buy off the shelf jacks that will fit those plugs?  I would rather not cut and splice if I don't have to.  The MAX fiche is acting up for me and I can't even find the explosion for the pods.  Is there a bulb holder part number that I can just replace my original with and use double filament 1157 style bulbs? :idunno:
  • IA
  • 1994 K1100RS
1973 Honda CL70-K3, 1975 Kawasaki 350 F9-C, 1994 BMW K1100RS, 2023 Honda CRF300L Rally ABS
Re: Extra leads inside the mirror housing on the fairing
« Reply #1 on: November 04, 2021, 02:35:04 PM »
What "extra" wires?
There's no factory part to run 1157 dual filament bulbs.
Run-n-lites Type 3: http://www.run-n-lites.com/AppGuide-Run-n-lites.html
Offline AtLarge
« Reply #2 on: November 04, 2021, 04:13:28 PM »
Mine:
The black plug is for the turn signal.  I can see the BMW 1369229 and AMP 926569 part number on that but, the white is blank.
  • IA
  • 1994 K1100RS
« Reply #3 on: November 04, 2021, 04:44:32 PM »
The white connector is not factory. Only the black one is.
Offline AtLarge
« Reply #4 on: November 04, 2021, 05:18:31 PM »
I think you nailed it with the Run n lites. When i took off the other one it still had the bulb holder like on that website. Bulb was black so obviously burned out which is why I had not noticed before. Thanks Frank. :-)
  • IA
  • 1994 K1100RS
