Author Topic: How does the rear brake fluid res. mount? on a k75  (Read 8429 times)
MC Dig
« on: December 11, 2011, 09:50:48 PM »
Hi,
I am still working on putting my bike (1987 k75s) back together after doing the clutch spline and drive shaft lube.
I am not sure how the mounting bracket for the rear brake fluid reservoir is supposed to attach.  The bracket has a threaded hole, does a bolt go up through the bottom of the battery tray?  Does anyone know how this goes?  I really should have taken pictures of all this as I took it apart, anyway; any help would be greatly appreciated.
Re: How does the rear brake fluid res. mount? on a k75
« Reply #1 on: December 11, 2011, 10:20:06 PM »
Right rear of the relay box.
MC Dig
« Reply #2 on: December 11, 2011, 10:27:57 PM »
Oh, I put up the wrong picture, sorry.  Here is the bracket I am talking about
« Reply #3 on: December 12, 2011, 06:09:25 AM »
The fluid bracket should be underneath the battery tray, and the screw should be
through a hole to the right from where you now have mounted it.
(where the screw now is mounted on the picture, is for the battery hold down bracket).
Inge K.
« Reply #4 on: December 12, 2011, 10:22:28 AM »
Never mind my previous post.  You have the early style brake reservoir:
MC Dig
« Reply #5 on: December 12, 2011, 04:02:34 PM »
Ok,
I saw that schematic, but it does not show the battery tray.
So,  the bracket fits on top of the battery tray like my picture and the bolt goes on from the underside?
« Reply #6 on: December 12, 2011, 06:16:26 PM »
The diagram shows a pre -86 (it`s two versions of the older type bracket)
Inge K.
Offline DRxBMW
« Reply #7 on: December 13, 2011, 07:00:51 AM »
FWIW, the plastic on the earlier style reservoir suffered greatly from UV exposure. Hence, it was quickly compromised.
Real reason BMW changed the location & plastic chemistry composition on the later models  :deal:
If you going to R&R, source a newer style reservoir.
Gary
Williamsport,Pa
1994 K 75 ABS "custom"
2005 F 650 GS
