Author Topic: K1100LT R/H handlebar switches & front master cylinder question  (Read 2758 times)
Offline BlueK11LT
I need to replace my throttle cable because the plastic 90 degree shaped end next to the throttle housing has broke,but i cant figure out how to remove & split the handlebar switch/front master cylinder unit.
Is this part actually one piece? and is there a step by step article on the forum about how to replace the K1100LT throttle cable?
Thanks
Dave
  • North East England
  • 1997 K1100LT,1977 Kawasaki Z650B1,1991 Honda ST1100
Re: K1100LT R/H handlebar switches & front master cylinder question
« Reply #1 on: June 09, 2021, 04:58:03 PM »
The part in red below is a little metal plate that holds the throttle tube on. You need to remove screws 4 and 5. If you have heated grips be careful not to screw up the wires where they connect at the outer end of the grip.
