Author Topic: Hi i'm new to the forum My BMW k75 has efi problems  (Read 1924 times)
Offline tetekto
« on: May 13, 2021, 10:09:55 AM »
Hi, i'm new to the forum, i'm tetekto.
i start My BMW k75 with the mass air flow meter conected, it'll idle fine, but when i apply throttle it doesnt Perform well, unless i press the starter button and apply throttle. when i disconnect the mass air flow sensor it idles,and Performs as it should, the only downside is,it'll smoke black without the mass air flow meter conected. I've cleaned the mass air flow meter with crc electrónica cleaner, i have changed the gas , i have changed the meter. can anyone give me any solutions to this problem, it'll be greatly appreciated. thankyou.
  • New orleans
  • Bmw k75
Offline milq
Re: Hi i'm new to the forum My BMW k75 has efi problems
« Reply #1 on: May 13, 2021, 12:59:16 PM »
The crankcase breather hose can cause hesitation off idle, it's very thin rubber that tends to crack near the clamps. Left side of bike, Z-shaped hose coming off of the airbox. I've been able to change them without removing the airbox, just slide clamps on first and then insert hose, hold your mouth right, etc.
  • Southern IL
  • 1988 K75S
« Reply #2 on: May 13, 2021, 01:41:27 PM »
Put the year of your moto's manufacture in your profile, tetekto.  How long have you owned this moto? Do you know its history? How many miles on the odometer?
Don't run the moto without the airflow meter connected. The breather hose milq described can be seen on the left side (clutch side) of the moto. It's often called the z-hose. You might have other vacuum leaks, too. Idle the moto then spray propane or carb cleaner on the hose. If the idle changes, it's leaking. Do the same with each of the three hoses that attach the throttle assembly to the air box.
  • 1995 K75 89,000 miles
« Reply #3 on: May 13, 2021, 02:00:33 PM »
Buy a new crank case breather hose anyhow. They only last a few years.
Max BMW - free shipping, no tax
https://shop.maxbmw.com/fiche/PartsSearch.aspx?&searchtype=undefined&parts=11151460480
