Author Topic: Need wider straighter k100rs bars s.o.s  (Read 5411 times)
Offline Blue85
« on: May 04, 2021, 08:55:37 AM »
Hi in the continuing saga to fit the bike the stock handlebars which ive adjusted to no help, are too bent and id like them to be up and back. What can/ should i buy. I am at a point where the bike will have to be sold if i cant fix this....thanks in advance
  • Coloma Wisconsin
  • 1985 k100rs
Happiness is a little yellow bird tweeting in a open field...
Re: Need wider straighter k100rs bars s.o.s
« Reply #1 on: May 04, 2021, 09:04:09 AM »
Post a photo of the handlebar taken from the side at tank level, Blue, and we'll figure out this situation.
Offline Blue85
« Reply #2 on: May 04, 2021, 01:37:44 PM »
* 6CA7EE89-5B57-4E1A-A60D-A70DE1652560-1.jpeg (71.54 kB . 768x576 - viewed 652 times)
  • Coloma Wisconsin
  • 1985 k100rs
Offline Blue85
« Reply #3 on: May 04, 2021, 01:39:56 PM »
* 77B147C1-FA5D-4FD9-BF2F-E95F8D59E54E.jpeg (63.94 kB . 768x576 - viewed 627 times)
  • Coloma Wisconsin
  • 1985 k100rs
« Reply #4 on: May 04, 2021, 01:45:43 PM »
k75c bars will move you up and back, but you may need to replace some cables and brake lines with longer ones any you'll get more buffeting from sitting higher.  I have the same bars on my 75S as your K100rs,  barbacks made a world of difference for me
« Reply #5 on: May 04, 2021, 01:47:04 PM »
I would see if I could find a "C" handlebar.  They were used on the naked K bike models.  It will be the correct diameter  to attach the switch gear and throttle.
Unfortunately, BMW doesn't stock them anymore, so you need to look for one on eBay.  Another alternative is Flanders.  They claim to have the 22mm bars the K bikes need.
« Reply #6 on: May 04, 2021, 02:32:50 PM »
These barbacks were advertised for sale here in March. They would both raise the bar and allow it to be tilted rearward. You'll need longer cables. Contact the seller for more details.
Offline Snowman
  • Aberdeen SD.
« Reply #7 on: May 12, 2021, 10:16:02 AM »
My RS came with these straight superbike bars on risers, sorry I cant tell you any manufacturer info but it may give you an idea of what is possible. I am in the middle of some reno' work so picture isn't great.
