So I have this K1100lt in my workshop and I can't seem to get the thing to start ok when cold.
I allready did quit some work on it
(some electrical gremlins to start with).
what I've done:
new plugs (old ones really black)
new filters and seals on the injectors
synchronisation
CO adjustment (1.7% now )
new fuel lines (cracked)
new fuel filter (old 2014)
new fuel pump (just as a test)
measured and tested the Co potmeter (goes from zero to 1040 Ohm, so that should be ok)
temp sensor from coolant has high resistance cold, drops when I manually heat it with a small torch.
Set the TPS with the coolant light method
symptoms:
When it's cold (let it sit overnight), it's hard to start, won't start with the "choke" on. When it starts, it cuts out, does that about 3 times, then it keeps running. you really have to "work" the throtlle to get it to rev properly. backfires through the Throttle bodies when cold.
When you can rev it cold, it dumps a cloud of black smoke.
once it warms up, all is good, starts perfect, runs great (did a testride and goes perfectly well).
any other things I should check? I'd like to get it over with
