Author Topic: Left blinker not working. BUZZING SOUND  (Read 3475 times)
Offline Steviescumbag
« on: April 07, 2021, 09:11:14 PM »
Hey good friends,
The left
Blinker and brake lights on my 1992 k75rt has stopped working. When I press the left blinker I hear a buzzing sound coming from the electrical box.
Right signal works fine
Any advice would be greatly appreciated
  • Toronto, Canada
  • 1992 bmw K75 Rt
Re: Left blinker not working. BUZZING SOUND
« Reply #1 on: April 07, 2021, 11:56:50 PM »
Does your bike have hazard flashers?  How are they working?
« Reply #2 on: April 08, 2021, 12:13:25 AM »
Check the condition of Fuse 3. Is it intact  Have you made any changes recently to the signal circuitry, like install LEDs.
« Reply #3 on: April 08, 2021, 02:19:25 AM »
Has the horn been working, and is it working at the moment? Has the triangular bulb warning light on the cluster been cancelling with the front and rear brake levers?
« Reply #4 on: April 08, 2021, 04:39:25 PM »
Thanks for the feedback .
Maybe I missed a few key notes lol
I removed the taillight, removed the cluster, and cut the hazards switch. I plan on putting a new Speedo and led brake light
But again the right blinkers works. I’m confused why one would work and the other wouldn’t. Could it be because I have no speedo connected or the cut hazards switch?
  • Toronto, Canada
  • 1992 bmw K75 Rt
« Reply #5 on: April 08, 2021, 07:29:06 PM »
You're in Toronto.  PM me and maybe I can help.
« Reply #6 on: April 08, 2021, 08:14:39 PM »
Yes I am Robert. Is there any other way we can discuss. For some reason I don’t have access to your profile so I can PM you.
I switched fuses that looked damaged.
  • Toronto, Canada
  • 1992 bmw K75 Rt
« Reply #7 on: April 08, 2021, 10:05:58 PM »
There's an icon under his avatar next to his reply—and under your avatar, too—that looks like a speech bubble. Click on that to compose and send a personal message.
  • 1995 K75 89,000 miles
« Reply #8 on: April 09, 2021, 09:46:58 PM »
One thing the blinkers and brakes have in common is earth at the rear. The buzz could be the horn relay as the blinkers try to steal earth from that path. might be worth having a look up the back.
« Reply #9 on: April 09, 2021, 10:16:04 PM »
I PMed you with my phone number.  Give me a call.  Might be a quick diagnosis and repair.
« Reply #10 on: April 11, 2021, 01:48:30 PM »
The horn is working btw.
  • Toronto, Canada
  • 1992 bmw K75 Rt
Offline pobiddy
« Reply #11 on: April 27, 2021, 11:11:22 AM »
Hey Stevie,
Not sure if this will help, but I had a similar issue recently. The turn signals are controlled by a computer located inside the electrical box. The case for the computer is bolted into the box with two gold-colored 10mm head bolts. Remove and unplug the case, and pry the computer board out of the case (you'll need a couple of small flat head screwdrivers and some patience). On the board you'll see two "towers". They are the turn signal relays. If your looking at them, the one on the right is for the left turn signal. You can plug the connector in and watch them work. My left signal would work intermittently, weather dependent, and while attempting to clean the contacts on the relay I noticed that the relay would move up and down more than expected. It turned out to be a cracked solder joint which was visible with a magnifying glass on the other side of the board. I added a dab of solder to it and the signals work perfectly now. Sorry I didn't take photos. I happened to be searching for something else when I came upon your post, so I joined in order to reply! Hi everyone!
  • USA
  • '87 K100RS
« Reply #12 on: May 11, 2021, 12:42:24 PM »
Hey guys. I figured it out and wanted to let you know. There was a bad connection that came loose on the indicator which is an incomplete circuit and caused the buzzing. Lolll. So simple.
Thanks though guys.
  • Toronto, Canada
  • 1992 bmw K75 Rt
« Reply #13 on: May 11, 2021, 07:21:21 PM »
Thanks, it's always helpful when the solution is given.
Was it a loose earth? Or positive.
Was it at the rear? Or front.
Or something else.
« Reply #14 on: May 11, 2021, 07:37:50 PM »
Good work Stevie.  I was thinking it would be a nice weekend to head out your way but no need now.
« Reply #15 on: May 12, 2021, 03:13:39 PM »
It was the front positive connection.
Lol no need Robert but we should ride together one day !
  • Toronto, Canada
  • 1992 bmw K75 Rt
