The bolts are stretch bolts Gryphon, so should not be reused.
They might be alright, but the build is not going to be cheap and I don't fancy throwing a rod on the dual carriageway.
There are a set of K1100 rods on eBay, which have the same part number and I can get the bolts for them.
Might order a pair of the newer bolts, which I have heard are different and see if they fit. If they do, happy days.
I have found a decent K1100 engine for sale nearby, but am wondering if the mounitngs, throttle bodies, clutch and gearbox are the same as the K100.
The engine had about 15PSI compression on 2 & 3 Scott. When we got it, it had nearly 100'000 miles on the clock and the speedo didn't work, so god knows how many miles it has actually done.
There is some wear in the cylinders, but not too much.
