Author Topic: lifting the K100LT with a MC lift  (Read 2725 times)
Offline Dan87
« on: November 28, 2020, 04:17:55 PM »
Hi, I'll replacing all fluids, pulling wheels and the drive shaft and rebuilding the forks and would like to lift the bike off the ground.
Is it possible to lift a 87 K100LT with the Craftsman MC lift? If it can be done, where is the balance point for lifting it?
Dan
  • CT
  • 1987 K100LT
Re: lifting the K100LT with a MC lift
« Reply #1 on: November 28, 2020, 06:57:53 PM »
The balance point is the oil pan itself.  Luckily the LT doesn't have a lower fairing like the K75S for example.  However, lifting by the oil pan makes changing the oil very difficult.
See this post on K100-forum showing how I added outriggers to the oil pan to stabilise the bike: https://www.k100-forum.com/t2088-motorcycle-jack-versus-motorcycle-lift#18167
You'll still need to use straps to secure the bike to the lift to prevent a tip-over.
Offline Dan87
« Reply #2 on: November 28, 2020, 07:20:06 PM »
Thanks Robert, I'll check it out once I have the access to do it. I just joined that site.
  • CT
  • 1987 K100LT
Offline Dan87
« Reply #3 on: November 30, 2020, 09:25:58 PM »
After working on the lift set-up for this bike for the better of the last two days I think I have it figured out.
Tomorrow I need to do a little more cutting and grinding of some plate steel and I'll let you know how it works.
  • CT
  • 1987 K100LT
Offline Dan87
« Reply #4 on: December 10, 2020, 02:03:47 PM »
Well, I got it. I'm able to lift the bike with the adapter plate I made and when it's strapped down the bike is rock solid and not going anywhere.
  • CT
  • 1987 K100LT
Offline Past-my-Prime
« Reply #5 on: December 10, 2020, 08:17:47 PM »
 :useless
 177381
Offline Dan87
« Reply #6 on: December 10, 2020, 09:19:47 PM »
:useless
 177381
LOL, okay, these are a couple of pictures I took while I was figuring out what I needed to do.
Tomorrow, I'll post a couple more now that I have it welded up and painted with a coat of paint that will make placing the plate under the bike. Since the bottom of the bike is black I used white paint so it will stand out under the bike. I think it will help in lining it up.
  • CT
  • 1987 K100LT
