Author Topic: Dot Dot Dot, which Dot is right??  (Read 2733 times)
Offline KCinSB
« on: November 25, 2020, 10:13:07 PM »
I guess its been 5 years ago, when the bike was still on the road, "we" did some brake bleeding. My K75 Buddy and I worked up a rig to pressure bleed the systems, and I recall it was a success after some fine tuning. I recall there was talk of the Dot4 at the time, and I think that's what we used. I still have Dot3 on the shelf in the garage, which I suspect should be simply discarded. I wanted to top of the Fwd reservoir, and now hear there is a Dot5 !!  Is that OK to use if I think the fluid in the bike is Dot4?
 What's with all the Dots for crying out loud..........     :idunno:
  • Santa Barbara, CA
  • SOLD
Re: Dot Dot Dot, which Dot is right??
« Reply #1 on: November 25, 2020, 11:28:23 PM »
Use fresh DOT 4. DOT 5 is not compatible with DOT 4 or your moto's brake system. Your DOT 3 suppy is probably water-contaminated and should be appropriately discarded.
Here's a link to a page that contains a K1100 Riders Manual. It contains specs of your moto's various fluids and other useful information. Scroll down to find the link; click on it to download a copy to your computer. You'll likely be less confused, in some ways, from here on out. The page also contains a link to a BMW K1100 shop manual.
« Reply #2 on: November 26, 2020, 05:27:29 AM »
+1 to what Laitch said.... NO to Dot5, NO to Dot3 in the bike.
If the container has been opened, and it's over 1 year old, toss it, even if it is compatible with your cars/trucks(which ever you have).
When I bought my R1100, the PO put Dot3 in the front and it and it messed up most everything, Master seals went out(caused a leak that stripped the paint), both front calipers wouldn't fully release.
Luckily I had the parts from my totaled K to replace them with. A good flush and refill with Dot4 and all is good again.....I've not been so bold as to test the ABS on the front, though it does work for the rear.
« Reply #3 on: November 26, 2020, 12:41:22 PM »
Brake fluid is one of the least expensive fluids you need for maintaining a brick.
Five bucks will buy enough to do a complete brake flush on a bike with ABS.  Keep the leftover stuff for topping up and toss it next year when you get a new bottle for the next flush.
Offline alabrew
« Reply #4 on: November 27, 2020, 02:18:03 PM »
It is DOT, not Dot, actually should be D.O.T.#
DOT = Department of Transportation and the number relates to the standards of the fluid.
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
