Author Topic: Need to raise brake pedal 1” any ideas?  (Read 2370 times)
Offline Blue85
« on: November 12, 2020, 11:28:28 AM »
Ok my k100rs rear brake pedal way low for me.i cant push my foot down need it flush with the footpeg any ideas?
  • Coloma Wisconsin
  • 1985 k100rs
Happiness is a little yellow bird tweeting in a open field...
Re: Need to raise brake pedal 1” any ideas?
« Reply #1 on: November 12, 2020, 01:05:20 PM »
First, make sure there is not air in the system and the reservoir is full.  My Ural had a similar issue with it's mechanical drum brakes, solve it by finding a rubber pedal cover the proper size. Might not raise it a whole inch but every little bit helps.
« Reply #2 on: November 12, 2020, 09:12:08 PM »
Saw and re-weld the brake pedal arm??  Glue on a hockey puck?
Offline Blue85
« Reply #3 on: November 12, 2020, 09:16:59 PM »
The bmw brake is set up and functioning as it should.i think i might epoxy a riser on top of it..can remove if needed
  • Coloma Wisconsin
  • 1985 k100rs
