Author Topic: ****Sold****  (Read 8540 times)
Offline Cherokee2072
****Sold****
« on: October 25, 2020, 05:43:40 PM »
Parting 1987 K75s.  60k miles, had it running, has an electrical issue I have been unable to isolate.  Have video of the bike running last month.  All parts available currently.  Brief list below, let me know your specific needs.  Willing to ship anywhere in North America.  Obviously freight has to be considered on heavy parts but I live near a ups hub, and have a wood shop so I can crate pieces for proper shipping also.
New shinko 705 tires front and rear with 10 miles on them.
New stainless brake lines Installed, new fluid, same 10 miles, lol.
New right hand switch gear.
Corbin saddle fair condition, usable for rider.
Fox remote reservoir Shock in good condition.
All lights in good condition
Plastics in good shape
Radiator excellent
Hoses good and extra set of Chinese silicone hoses
Engine sounds good (when it runs)
Trans shifts smooth.
Brakes function as they should.
Discs are good
tragkorbs are fair.  Patches are good, hinges may need attention in the future, brackets are good.
Tank has no leaks, some minor rust around filler, looks like it had a tank bag that trapped moisture, pretty clean inside.
Let me know what you need.  Working on pricing, I will publish a list as soon as possible.
Located in Northwest North Carolina
  • NC
  • 87 K75S
Online Past-my-Prime
Re: 1987 K75S Parts N.C.
« Reply #1 on: October 26, 2020, 10:53:52 AM »
Hi Cherokee,
What can you tell me about the Fox shock?
So sorry to hear that your fueling issue was not resolvable.  My bike is such a pleasure to ride, I feel regretful every time one of these gets parted out (although I realize that parting out one bike can give several others an extension on their lives). What's worse in my view is when people cut and hack to make some kind of cafe racer that will then rarely be ridden but that's a topic for another day.
Where was I? The shock. Would probably be an upgrade on my 31 year old original equipment rear shock. What model? Does anyone know if it'll fit a bike with ABS (I know that some models of shock interfere with the ABS motor). Any advice, in advance of me making an offer, would be appreciated.
Best of luck with your sales.
« Reply #2 on: October 26, 2020, 12:45:01 PM »
Good afternoon,
The shock was on the bike when I got it.  I will gladly take more pics and send you as much detailed information as I have.  Regarding interfering with ABS.  The  reservoir mounts high, granted mine doesn’t have abs, from what I have seen of the abs pump location I can’t see it being in the way.  I will post pics for you this evening.
Thanks
  • NC
  • 87 K75S
« Reply #3 on: October 26, 2020, 12:53:50 PM »
I've had Fox Twin Clickers on a couple of my K bikes.  Currently have one on my '88 K100RS.
They are pretty nice once you get them dialed in.  They have adjustable spring preload, and compression and rebound damping.  They are rebuildable and you can experiment with oil viscosity as well.
As far as ABS, it's not a problem.  The remote reservoir mounts on the rear frame loop, the one cafe hackers cut off, behind the tragkorb mount.  It's a snug fit between the back of the tragkorb and the mudguard, but only takes a little bit of fiddling to clear everything.
« Reply #4 on: October 26, 2020, 07:31:25 PM »
Had an overnight PM (first one to reach out) purchase the windscreen, bags, shock and brake lines.  All other parts are still available.  I am trying to be diligent about letting first to reach out have first right of refusal.
  • NC
  • 87 K75S
Offline thestza
« Reply #5 on: January 11, 2021, 08:12:51 PM »
evening. not sure if this post is still active...
do you have the lower fairing / belly pan available?
  • gross angeles
  • 1988 k75$
« Reply #6 on: January 11, 2021, 08:46:03 PM »
I do still have several parts, will update list soon.  All plastic with the exception. Of the tail has been sold though.
  • NC
  • 87 K75S
Offline SDCR john
« Reply #7 on: January 19, 2021, 01:35:12 PM »
Rear tire available? I am in Pa. zip 18914.
1994 BMW K75S Dakar Yellow #0154446
1983 Moto Guzzi 850 Le Mans
2000 BMW R1100 RS
Bucks County Pa.
« Reply #8 on: January 19, 2021, 02:15:57 PM »
SDCR it is.  Rim with spacer shim and new tire $120 shipped?  Let me know.  Thanks Kevin
  • NC
  • 87 K75S
Offline johnclaude
« Reply #9 on: February 04, 2021, 06:07:34 PM »
Do you happen to have the instrument cluster still? Does it work and have the half circle pins in the back?
Thanks, John
  • Aurora
  • 1988 K75C
Offline MonkeyMcBean
« Reply #10 on: March 10, 2021, 05:49:21 PM »
I need some plastics. do you still have the side panels/battery covers? do you know if they're identical to the '94? how about the side cases? do you know if they're the same on the '94?
  • North Dakota, USA
  • 1993 k75s
This is it. F*** it. It is what it is.
« Reply #11 on: March 10, 2021, 07:46:17 PM »
Looking at discs and possibly SS brake lines - is this an ABS model?
Probably not too far away - may be interested in what's remaining.
« Reply #12 on: March 11, 2021, 09:42:19 AM »
Brake lines and front discs are sold.  I will check on the rear tonight can’t remember for sure.  My cell is 336-977-1247 if you are interested in the entire lot I can give you an inventory.
Thanks Kevin
  • NC
  • 87 K75S
Offline Regrider
« Reply #13 on: April 11, 2021, 10:53:59 PM »
I am close by in NC could I visit to check on available parts and possibly purchase?
  • Canton, NC
  • 1985 K100,1987 K75, 1965 Triumph Bonniville
Offline mcgyver74
« Reply #14 on: April 18, 2021, 05:12:11 PM »
Sent you a PM,  Interetsted in Fuel Tank and Fuel Pump if they are still good
Also the gas cap and key :)
Thanks
  • Jersey City NJ
  • 1990 K75S
Jersey City NJ
1990 K75S
