Author Topic: Cooling fan temp on/off  (Read 5319 times)
Offline Cafe racer
  • Café racer
« on: October 01, 2020, 09:57:15 PM »
Checking the cooling fan operation. I had the bike idle untill the fan came on, gauge just above the centre, it run for only a minute, and gauge dropped to centre, this cycled a few times, I pointed my temperature measurement gun at the water pump, 105°c before tha fan, then when fan stopped it was 95°c again I cycled this a few times, the bike was in direct sun and ambiance temperature was around 26°c
So is this normal? Looks ok to me...
  • Japan
  • K100RS 1988 2 valve
Offline blackie1
  • christchurch nz
Re: Cooling fan temp on/off
« Reply #1 on: October 02, 2020, 03:29:08 AM »
sounds like it is operating correctly
this from
https://ibmwr.org/index.php/2007/06/01/cooling-fan-diagnostics/
regarding two valve K bikes
 according to the 93 K75S Owners' Manual:
Thermostat starts to open at 85 C                (185 F)
Fan Cut-in at 103 C                              (217 F)
Overheat Warning Light at 111 C                  (232 F)
Pressure relief valve opens at 120 C/1.1 bar     (248 F/16 psi)
Vacuum relief (return valve) opens at -0.1 bar   (-1.45 psi)
  • 1991 K75RT naked 67,000kms
Tags: fan temperature
