Author Topic: What Is Causing This Oil Leak  (Read 5082 times)
Offline k
« on: August 23, 2020, 09:06:26 PM »
When I am running for sustained periods above 70, or so, I get an oil leak from the right side of the bike. When I back off, the leak subsides, a bit. The crankcase gasket has been replaced, and the problem is unchanged.
  • Indiana
Offline blackie1
  • christchurch nz
Re: What Is Causing This Oil Leak
« Reply #1 on: August 24, 2020, 04:48:37 AM »
can we assume , whilst on the center stand, your engine oil level at rest sits at/near the dot in the center of your sight glass?
  • 1991 K75RT naked 67,000kms
« Reply #2 on: August 24, 2020, 09:19:51 AM »
and your oil cap has an o-ring?
« Reply #3 on: August 24, 2020, 09:37:30 AM »
I think there's a screw hole in that bottom corner of the airbox, if you're getting enough blowby to collect oil in the filter housing it could be leaking out there.  And check the o ring on the oil filler cap.
« Reply #4 on: August 24, 2020, 10:59:53 AM »
If it's pooling at the red arrow, it must be flowing from some place to get there. Clean off all traces of oil then apply bath powder on the area around the upper crankcase cover seam and the pooling area. Blow off the excess, go for a ride at 70mph, stop, then see if any powder residue reveals tracks from the source. It's likely the crankcase seam is leaking, especially if the cover has been off or it has received a shock from the bike's falling over on that side.
Offline k
« Reply #5 on: August 24, 2020, 10:14:21 PM »
I put the oil cap from the K1100 on the K100, put some corn starch on it, and took it out for a half hour.
I can't find a leak.
  • Indiana
« Reply #6 on: August 25, 2020, 01:26:07 AM »
Congratulations on finding the source of the problem.  112350
Offline k
« Reply #7 on: August 25, 2020, 06:11:00 PM »
I wouldn't go that far. I just didn't spot a leak in a half-hour ride.
  • Indiana
« Reply #8 on: August 25, 2020, 08:23:47 PM »
True, it seems like you didn't go that far. I rescind congratulations and substitute, Have a nice day, whenever that might start.
Offline k
« Reply #9 on: August 26, 2020, 10:31:58 PM »
Still leaking. I can't make it leak with high RPM and low speed. It will leak at high RPM and high speed.
  • Indiana
« Reply #10 on: August 27, 2020, 12:15:03 AM »
Did you try tracing the leak with the cornstarch method again?
Offline koapono
« Reply #11 on: August 27, 2020, 06:59:48 AM »
just a thought:
there are a couple of crankcase vents in the area under the air-box. If those hoses/rubber caps are original they might be source of leak. The engine block has many nooks and crannies under the air-box, they may be filling with oil and leaking out in area you highlighted.
  • 1994 K1100LT
Offline Snowman
  • Aberdeen SD.
« Reply #12 on: October 15, 2020, 05:33:39 PM »
I agree with Koapono, Likely a vent hose either split or out of place. Sustained high engine RPM makes it worse.
