Author Topic: Dying K75  (Read 3374 times)
Offline Wirelic
Dying K75
« on: August 17, 2020, 10:00:10 AM »
Need some help.  I just got an 86 K75.  It runs ok if I keep driving it, but if I stop at a stop sign, it dies.  As long as I ride at speed, it runs fine.  Stooping the bike and it dies.  Any ideas or suggestions?
Thank you very much for helping
  • Green Bay, WI
  • 88 K75, 77 Bonneville
Re: Dying K75
« Reply #1 on: August 17, 2020, 10:37:04 AM »
How many miles on the odometer? Have you looked into the empty fuel tank to determine its condition? If you don't know the age of the fuel filter, replace it immediately. Check on the condition and tightness of the fuel tank hoses and their connections.
Report back.
Re: Dying K75
« Reply #2 on: August 17, 2020, 10:45:51 AM »
Fresh gas, run some Techtron, check the crankcase vent hose for cracks, (back left side of engine) what Laitch said
Re: Dying K75
« Reply #3 on: August 17, 2020, 12:03:08 PM »
+1 on the crankcase vent hose.  Also check the rubber caps on the throttle body balancer ports.  Make sure they are all there and none of them are cracked.
When was the last tune up with valve clearance check and throttle balance done?
Keep your fingers crossed that the throttle body bushings aren't cracked and need replacing.
Offline Wirelic
Re: Dying K75
« Reply #4 on: August 18, 2020, 11:56:33 AM »
Thanks very much, guys.  I’ll check on those suggestions.  It might take awhile, though, as I’m quite busy right now.
  • Green Bay, WI
Offline volador
  • NEEDS MORE CHROME
Re: Dying K75
« Reply #5 on: August 18, 2020, 12:52:42 PM »
add a litre of Kerosene or Diesel a few tank fills flush system
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Re: Dying K75
« Reply #6 on: August 18, 2020, 03:19:54 PM »
Diluting gasoline with ~5% kerosene or diesel fuel seems pointless and repeated use in ratios of that magnitude could cause carbonification and power loss in a Brick.
Offline volador
  • NEEDS MORE CHROME
Re: Dying K75
« Reply #7 on: August 19, 2020, 12:15:28 AM »
What's the point of running Techtron?
  • NYC NY
Re: Dying K75
« Reply #8 on: August 19, 2020, 11:32:42 AM »
The point of using Techron is to take advantage of lubricants and solvents contained in its proprietary formula to reduce deposits throughout the fuel system. If the idea is held that Techron contains no effective proprietary formula and only consists of repackaged kerosene, diesel fuel, or Stoddard solvent, there is no reason to use it; however, a 10fl.oz. container of Techron amounts to only slightly more than 1% of a 22L fuel tank's contents.
Gasoline combusts in mist droplets but kerosene combusts in vapor so should be preheated for complete combustion. Until the chamber is hot enough for kerosene to vaporize, it will deposit carbon in the chamber and elsewhere which will interfere with performance if enough of it accumulates from cold starting. A proportion of 5% kerosene or greater in fuel contents will likely cause accumulation of carbon.
Re: Dying K75
« Reply #9 on: August 19, 2020, 01:09:48 PM »
when was the last time the bike got a complete tune up?  if you don't know the answer or it has been a few years, it is time.
Offline Wirelic
Re: Dying K75
« Reply #10 on: August 19, 2020, 04:50:39 PM »
I don’t know when it last got a tune up.  It’s new to me.  I’ll sort thru everyone’s suggestions and let you know what I find out or what turns up.   Sounds like it’s overdue for a service.
  • Green Bay, WI
