Author Topic: Battery in tail  (Read 4453 times)
Offline 85killzillaRS
  • BumbleBrick
Battery in tail
« on: August 12, 2020, 03:55:50 PM »
I want to mount the battery in the tail. when I had the battery out I hooked up to the end of new 3' extension leads and meter read 13.3 volts. when I plugged it all together and turned the key to the on position it was dead, no power to the dash lights, nothing.
what am I missing here
  • El Paso, TX
  • 85K100RS
Christopher
past- 68 BenelliDynamo, 74 HodakaAce100, 76 BultacoMatador250,
85 HondaNighthawk650, 83 HondaCB1100F, 90 KawasakiZX10
Someday マ値l get a bike from this century (no hurry)
Re: Battery in tail
« Reply #1 on: August 12, 2020, 04:31:34 PM »
Verify that the cables are connected to the correct terminal polarity.
  • BumbleBrick
Re: Battery in tail
« Reply #2 on: August 12, 2020, 04:37:17 PM »
polarity is good,
red to red & black to black
  • El Paso, TX
  • 85K100RS
Christopher
Re: Battery in tail
« Reply #3 on: August 12, 2020, 05:23:36 PM »
That doesn't tell me much. What is the voltage between the negative and positive battery terminals right now?
  • BumbleBrick
Re: Battery in tail
« Reply #4 on: August 12, 2020, 05:48:34 PM »
13.3 at battery terminals & 13.3 at end of extension leads , I hooked it up to bike with correct polarity
I'm putting it back to stock for the moment & taking a quick ride
going to try and beat my old record of 15 min that I had with old coils  112350
  • El Paso, TX
  • 85K100RS
Christopher
Re: Battery in tail
« Reply #5 on: August 12, 2020, 09:05:01 PM »
I assume you connected the new leads to the all of the original + and = battery leads?
  • BumbleBrick
Re: Battery in tail
« Reply #6 on: August 12, 2020, 09:17:25 PM »
yes, I hooked up to the exact ones that I are connected now,  minus extensions
and it is powered currently
  • El Paso, TX
  • 85K100RS
Christopher
Re: Battery in tail
« Reply #7 on: August 12, 2020, 10:52:56 PM »
Looks like you've found the problem.  icon_cheers   Did you set a record for ride length? :popcorm
  • BumbleBrick
Re: Battery in tail
« Reply #8 on: August 12, 2020, 11:50:21 PM »
no record ride length yet, just went around the block, some day i値l do a few miles
for the lead extension deal, マ tried some 10 guage wire and it looks like that will do the trick icon_cheers
that will be my morning project for tomorrow
  • El Paso, TX
  • 85K100RS
Christopher
