Author Topic: What do the front fairing bracket bolts on K75rt look like  (Read 3250 times)
Offline K75RT Keith
« on: June 29, 2020, 01:42:29 PM »
I don稚 think the last person to pull the fairing bracket used the correct bolts on my 90 K75rt. Anyone have a description or photo that shows the correct bolt.
Thanks
1990 K75RT
Re: What do the front fairing bracket bolts on K75rt look like
« Reply #1 on: June 29, 2020, 02:05:01 PM »
Click on Diagram #46_0119 Fairing Bracket in section 46-Frame, Fairing, Cases at this site for size, thread pitch and length of fasteners in the bracket parts list.
Offline K75RT Keith
« Reply #2 on: June 29, 2020, 05:40:38 PM »
I知 trying to determine if the mounting bolts should have a pointed end
1990 K75RT
« Reply #3 on: June 29, 2020, 07:38:34 PM »
To which bolts in the diagram are you referring?
Offline K75RT Keith
« Reply #4 on: June 29, 2020, 07:53:10 PM »
The bolts that hold the bracket to the neck of the frame.   If you致e remove the fairing and bracket from an RT, you値l know which ones I知 asking about. I read on here somewhere that the bolts have an affect on the fluid block in the frame neck
1990 K75RT
« Reply #5 on: June 29, 2020, 10:33:06 PM »
M6x18 with tapered end. $4.38 a piece at Max BMW.  See section 31, diagram 31_0387, part list number 03, BMW part number 46 51 2 311 423.
