Author Topic: BEP 3.0 Fuel Level Warning Light  (Read 8209 times)
Offline Grant
« on: June 21, 2020, 11:16:43 AM »
I need some help figuring how to get an LED fuel warning light to work with the BEP. My bike is an '84 so has no tank float.
The BEP outputs a signal when the fuel level drops below 4 litres, my problem is how to use that signal to light up the warning light on my custom dash, (the signal switches from 100 to 10 ohm below 4 litres).
  • Abbotsford BC Canada
  • 1984 K100 0005895
Online Laitch
Re: BEP 3.0 Fuel Level Warning Light
« Reply #1 on: June 21, 2020, 11:32:36 AM »
Did you flip this switch on the underside of the BEP to see what would happen?
Offline Grant
« Reply #2 on: June 21, 2020, 12:01:15 PM »
Yes it is on the correct setting. The BEP only provides a signal, no power or ground to light up the warning light, I require an electronic solution to make the warning light turn on or off when the signal is triggered by the BEP.
My aftermarket gauges don't have a built in fuel level function.
  • 1984 K100 0005895
Online Laitch
« Reply #3 on: June 21, 2020, 05:05:18 PM »
Like this?
Offline Grant
« Reply #4 on: June 21, 2020, 10:48:56 PM »
Yes, something that will make the warning light turn on when the signal is sent from the BEP. This how the original dash worked? There is probably a circuit in the original dash that does this, as a light would come on to indicate low fuel.
I don't want to scavenge the original dash as it has some resale value or can be useful to someone keeping their bike in original condition, (only 32,000 km on the odometer).
  • 1984 K100 0005895
Online Laitch
« Reply #5 on: June 22, 2020, 04:09:51 PM »
A spiyda.com device looks like the thing for you then, and you can leave the BEP out of the equation if that's what you want.  112350
