What you've been doing so far is a partial tuneup. You should now check the idle speed, throttle body synchronization and CO value, correcting each if necessary. When you finish these tasks you'll have done a complete tuneup if the valve clearances, spark plugs and air filter were ok. Which manual are you using? Ideally, all these steps are done one after the other at one go, however long it takes.
