Author Topic: Chasis Wiring Harness needed  (Read 2684 times)
Offline asafl
« on: June 08, 2020, 11:24:28 AM »
Hello.
So few days ago I stop and wait for a green light, and the bike shuts down. I try to start - nothing. Then - smoke comes under the gas tank. I pull the bike off road, and start seeing flames coming out. I take the key out of the switch and run to get an extinguisher. Suddenly I head the bike get ignited alone. Fun. We pull the battery off and powder the entire bike.
In the garage, we lift the gas tank and see all the damage. I think I need the wiring harness - and probably the relays.
Would appreciate any insight on this - any parts recommended to have in hand to make sure fix is not as long, to understand (maybe!) the source of this mess and basically anything a smarter more experienced individual than me can assist with.
On the PN side, my chasis number (VIN?) is WB1051306F0041094 and I believe the PN for the harness is 6-11-11-459-140.
Please assist, if you can :)
Thanks!
Asaf.
  • Tel Aviv
  • 1986 K100RS
Re: Chasis Wiring Harness needed
« Reply #1 on: June 08, 2020, 04:32:19 PM »
I'll guess the insulation on one of the positive wires (not protected by a fuse) was worn, and made contact with say the frame, causing a short.
It is simple and easy to install a circuit breaker so that if something like that happens again, it will trip rather than burn.
Offline volador
  • NEEDS MORE CHROME
« Reply #2 on: June 08, 2020, 07:41:17 PM »
I'll guess the fuel sender unit O-ring was at fault along with it the associate 4pin connector. You lucky no BADA BOOM
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
