80,000 mile K1100RS ABS rear brake started getting hot a couple months ago. Started pinging after riding around the block and the dust boots melted to the pistons.
I have tried:
Flushing fluid (negatory)
Cleaned pins which were gunky and rusty. (Negatory)
Replacing hose from resevoir to MC - all other hoses had been replaced with braided lines (negatory)
Measured lateral runout with dial caliper, .003 max deflection, within spec.
I just finished rebuilding the caliper and putting new pads in, since the old pads had not worn evenly.
Now I am spinning it around by hand and I still hear the pads kissing the disc for about 1/3 of travel, same spot each time after applying brakes. Same pattern as before rebuilding the calipers.
Got the dial indicator back out, still seeing minimal lateral error, nothing beyond spec.
Should I try bedding these pads in or is that a false hope?
Only thing I haven't done is fux with the master cylinder.
Time for a new master cylinder/ MC rebuild?
upgrade to comprehensive insurance and ride it around hoping it spontaneously combusts?
